Visual LISP, AutoLISP and General Customization
Laydel by lisp
9 REPLIES 9
Message 1 of 10
msarqui
1372 Views, 9 Replies
Laydel by lisp
Hi guys,
Based on the tip from *Paul Turvill : http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Delete-a-Layer-with-Laydel/td-p/21742... I made this routine:
(defun c:DeleteLayerTavail ()
(setq ss (ssget "x" '((8 . "Tx-Travail"))))
(command "_.erase" ss "")
(princ)
The routine works great but I notice that if I don’t have this layer, it will return an error. Could someone update this to just ignore if the drawing don’t have the layer Tx-Travail?
I need this because I will use this routine together with another routines and in some cases I will not have the layer specified.
Thanks for help!
9 REPLIES 9
Message 2 of 10
pbejse
in reply to: msarqui
@msarqui wrote:
Hi guys,
(princ)
Thanks for help!
      (if (setq ss (ssget "x" '((8 . "Tx-Travail"))))
      		(command "_.erase" ss ""))
      (princ)
or
(defun DeleteLayer (lay)
      (cond ((and
					(tblsearch "LAYER" lay)
					(setq ss (ssget "x" (list (cons 8 lay))))
          (repeat (setq i (sslength ss))
                	(entdel (ssname ss (setq i (1- i)))))
      (princ)
(deleteLayer "layername")
Message 3 of 10
msarqui
in reply to: pbejse
Why it does not work if the layer is not in the current space.
Can be set to erase the layer in both spaces like the LAYDEL command?
Thanks!
Message 4 of 10
pbejse
Thanks!
Try this instead
  (vlax-for layout  (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (vlax-for i  (vla-get-block layout)
      (if (eq (vla-get-layer i) lay)
        (vla-delete i)))
Message 5 of 10
msarqui
in reply to: pbejse
Hello pbejse
I start to understand and do some basic routines but my knowledge is still very small. So when I see these VLA things I do not understand at all. This is like chinese language to me 😞
So, I tried this :
(defun c:DeleteLayer (lay)
(vlax-for Tx-Travail (vla-get-block layout)
(if (eq (vla-get-layer Tx-Travail) lay)
(vla-delete Tx-Travail)))
And I got this error:  Command: too few arguments
Thanks for your time.
Message 6 of 10
pbejse
@msarqui wrote:
Hello @pbejse
So, I tried this :
 msarqui
To use  snippet i posted
(DeleteLayer "Tx-Travail")
It is a generic routine that accepts a layer name as argument
If you need to a command to work for a specific layer
(defun c:DeleteLayerTavail ()(DeleteLayer "Tx-Travail"))
Also take note that the layer name is case sensitive: in that case we can modify the routine to
      (if (eq  (strcase (vla-get-layer i))
                   (strcase lay))
        (vla-delete i)))
Better yet , to use the routine for one or more layer names
(defun DeleteLayer  (lst)
      (if (member (strcase (vla-get-layer i))
                  (mapcar 'strcase lst))
        (vla-delete i)))
(DeleteLayer '("Tx-Travail" "otherLayer" "AnotherLayer"))
Now, going back to your original post
(defun c:DeleteLayerTavail ()(DeleteLayer '("Tx-Travail")))
HTH
Message 7 of 10
msarqui
in reply to: pbejse
This two works great and realy fast:
(defun c:dlt1 ()(DeleteLayer "Tx-Travail"))
(strcase lay))
(vla-delete i)))
(defun c:dlt2 ()(DeleteLayer "Tx-Travail"))
(vla-delete i)))
But this one with the list returns "nil" and do nothing:
(defun c:dlt3 ()(DeleteLayer '("Tx-Travail" "Tx-1" "Tx-2" "Tx-3")))
(vla-delete i)))
Message 8 of 10
pbejse
(vla-delete i)))
Works on my end , its either there are no objects on the listed layer or the layer doesnt exist. or worse the entities are on a locked layer.
What you can do is add a sub to unlock all layers then invoke the command
(defun DeleteLayer  (lst / n)
  (setq n 0)
      (if (member (strcase (vla-get-layer i)) (mapcar 'strcase lst))
        	(progn (vla-delete i)
                  	(setq n (1+ n)))
  (princ (strcat "\n" (itoa n)  " Objects deleted"))
  (princ)
 HTH
Message 9 of 10
msarqui
in reply to: pbejse
I got this error: Command: Automation Error. On locked layer
So I made this:
(command "-layer" "s" "0" "u" "*" "on" "*" "t" "*" "")
  (setq n 0)
                   (setq n (1+ n)))
  (princ)
And now it works. 🙂
Message 10 of 10
pbejse
So I made this:
And now it works. 🙂
Good for you msarqui 🙂
"i'll leave the "unlocking" to the user"
BTW: (command "_layerp");;<-----
”Boost
