style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Bill Gilliss" <
href="mailto:bill@realerthanreal.com">bill@realerthanreal.com> wrote in
message
href="news:6095486@discussion.autodesk.com">news:6095486@discussion.autodesk.com...
Here's a 2D convex hull routine I spent an
enjoyable afternoon on. Draws an LWpolyline parallel to the WCS -- haven't yet
worked out just where to use (trans) to generate the hull parallel to other
UCS's.
-Bill
face="Courier New, Courier, monospace">;|
ConvexHull2D.lsp
draws,
parallel to the WCS, the 2D Least Convex Hull
of a set of POINTs, by the
wrapping method
by Bill Gilliss
bill dot gilliss at
aya.yale.edu
ver 1.0 Dec 24 2008 - initial release
Comments and
suggestions always welcome.
(defun c:ConvexHull2D
getPointList getBasePoint findSmallestAngle ptlist hullList pts
p1 p3
(defun
getPointList ( / n )
(setq ptlist nil hullList nil)
(prompt "Select points: ")
(setq pts (ssget '((0 .
"POINT"))))
(setq n 0)
(while (< n (sslength
pts))
(setq ptlist (cons (cdr (assoc 10 (entget (ssname
pts n)))) ptlist))
(setq n (1+ n))
(defun
getBasePoint ( / n en ed enx eny xmax ymax)
(setq n 0)
(while
(< n (sslength pts))
(setq en (ssname pts
n)
ed (entget
en)
enx (cadr
(assoc 10 ed))
eny
(caddr (assoc 11
ed))
(if (= n 0)
(setq basepoint en xmax
enx ymax eny)
(if
(> enx
xmax)
(setq
basepoint en xmax enx ymax
eny)
(if
(and (equal enx
xmax)
(> eny
ymax)
(setq basepoint en xmax enx ymax
eny)
);if
);if
);if
(setq n (1+ n))
);while
(setq basepoint (cdr (assoc 10 (entget
BasePoint))))
(setq p1 basepoint)
(setq p3
nil)
(defun findSmallestAngle ( / n p2 smallestAng)
(setq smallestAng (* 2 pi))
(setq n 0)
(while
(< n (length ptlist))
(setq p2 (nth n ptlist))
(if
(and
(not (equal p1
p2))
(not (member p2
hullList))
(progn
(setq ang (angle (trans
p1 0 1) (trans p2 0 1)))
(if
(and
(< ang
smallestAng)
(not (equal ang 0.0
1e-12))
(setq
smallestAng ang p3
p2)
(setq n (1+
n))
);while
(defun
makePolyline ()
(setq polylist
(list
'(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 .
"AcDbPolyline")
(cons 90 (length
hullList))
'(70 .
1)
(setq vtxlist (mapcar '(lambda (coord)
(cons 10 coord)) hullList))
(setq Polylist (append Polylist
vtxList))
(entmake PolyList)
(command "._undo" "_begin")
(if (tblsearch "UCS" "ConvexHull2D")
(command "._UCS" "_save" "ConvexHull2D"
"_y")
"ConvexHull2D")
(getPointList)
(getBasePoint)
(setq *ucsicon (getvar
"ucsicon"))
(setvar "ucsicon" 0)
(while (not
(equal basepoint p3))
(findSmallestAngle)
(setq hullList (cons p3
hullList))
; (command "line" (trans p1 0 1) (trans p3 0
1) "")
(command "ucs" (trans p3 0 1) (trans p1 0
1) "")
(setq p1 p3)
);while
(makePolyline)
(setvar "ucsicon" *ucsicon)
(command "._UCS" "_restore" "ConvexHull2D")
(command "._UCS"
"_delete" "ConvexHull2D")
(command "._undo"
"_end")
);defun
(defun c:ch2d ()
(c:ConvexHull2d))
(princ "ConvexHull2D loaded. Enter CH2D to
run.")
(princ)
Hi Bill,
Thanks for sharing. I just copied
your code into the Vlide, loaded it, and typed CH2D at the command
line. It asked me to select points so I selected by the Window
method. It crashed. I ascertained (Last Break Source) the problem
was somewhere in the following line:
p1 0 1) "")
"Bill Gilliss" <
message
href="news:6095544@discussion.autodesk.com">news:6095544@discussion.autodesk.com...
Fatfreek wrote:
Hi Bill,
Thanks for sharing. I just copied your
code into the Vlide, loaded it, and typed CH2D at the command line. It
asked me to select points so I selected by the Window method. It
(command "ucs" (trans p3 0 1) (trans p1 0 1)
Thanks for the feedback.
Here
is a much faster and more reliable version: (command "UCS" ...) calls
have been eliminated and point list pruning has upped performance by about 4x.
5000 points in just over 2 seconds. Not too shabby.
I still need
to localize the variables and add error handling, but it is pretty unobtrusive
code -- only plays with cmdecho.
I've been testing it hard all evening
(note to self: get a life!), so now it is your turn. Let me know how it
goes.
-Bill
ConvexHull2D.lsp
draws the
Least Convex Hull of a set of POINTs as a 2D polyline
in the *current*
UCS.
by Bill Gilliss
bill dot gilliss at aya.yale.edu
ver 1.0 Dec
25 2008 - initial release
Notes:
- The routine will generate
different hulls for different UCS's, so is
most useful when in PLAN view for the current UCS.
- Points may be
2D or 3D - Z coordinate is ignored. Polyline is drawn
in
current XY plane.
- Uses the
wrapping method, starting from the farthest right point.
- Pruning
that eliminates most interior points before analysis results
in
approx 4x speed increase.
Comments
and suggestions always
welcome.
(defun
(setq ptlist nil hull nil)
(prompt
"Select points: ")
(setq pts (ssget '((0 . "POINT"))))
(setq n 0)
(while (< n (sslength pts))
(setq pt (cdr (assoc 10 (entget (ssname pts n)))))
(setq
pt (trans pt 0 1))
(setq pt (list (car pt) (cadr
pt)))
(setq ptlist (cons pt
ptlist))
(setq n (1+ n))
(defun
getNEWSPoints ( / n en ed enx eny xmax ymax)
(setq n 0)
(setq pt (nth n ptlist) ptx (car pt) pty (cadr pt))
(setq eastPt
pt
xmax
ptx
ymax
pty
xmin
ptx
ymin pty)
(setq n 1)
(while
(< n (length
ptlist))
pt))
(if (> ptx
xmax)
(setq EastPt pt xmax
ptx)
(if (< ptx
xmin)
(setq
WestPt pt xmin
ptx)
(if (> pty
ymax)
(setq NorthPt pt ymax
pty)
(if (< pty
ymin)
(setq SouthPt pt ymin
pty)
(setq n (1+
n))
);while
(defun findMinAngle ( / n p2 ang
minAng )
(setq p3 temp)
(setq
minAng 2pi n 0)
(while ;;optimize this loop as
much as possible
(< n (length
ptlist))
(setq p2 (nth n
ptlist))
(if (not (equal p2
p1))
(progn
(setq ang
(rem (+ 2pi (angle p1 p2) (- prevang))
2pi))
(if (and (<
ang minAng) (not (equal ang 0.0
1e-12)))
(setq minAng ang p3 p2
(setq n (1+
n))
);while
(setq hull (cons p3
hull))
(setq prevang (angle p3
p1))
(command "._line" p1 p3
(ssadd (entlast)
lines)
(setq temp p1 p1
p3)
(defun prunePoints ( / NP SP EP WP p1 p2 p3)
(setq
NP northPt EP eastPt WP westPt SP southPt)
(setq
NEWSpts (list NP EP WP SP))
;;prune north
half
(setq p1 EP p2 NP p3 WP)
(prune)
;;prune south half
(setq p1 WP p2 SP
p3 EP)
(prune)
(if (or (equal EP
NP)
(equal NP
WP)
(equal WP
SP)
(equal SP
EP)
(progn
;;prune west
half
(setq p1 NP p2 WP p3 SP)
(prune)
;;prune east half
(setq p1 SP p2 EP p3
NP)
(prune)
);progn
);if
(defun prune ()
(if (and (/= p1 p2) (/= p2
p3))
(progn
(setq
TriangleArea (area3p p1 p2 p3))
(foreach pt
ptlist
(progn
(setq
testArea
(area3p p1 p2
pt)
(area3p p2 p3
pt)
(area3p p3 p1
pt)
(if
(and
(not (member pt
NEWSpts))
(equal testArea TriangleArea
1e-8)
(setq
ptlist (vl-remove pt
ptlist))
);progn
);progn
);if
(defun area3p (p1 p2 p3 / a b c s)
(setq
a (distance p1
p2)
b (distance p2
p3)
c (distance p3
p1)
s (* 0.5 (+ a b
c))
(sqrt
s
(- s a)
(- s b)
(- s c)
;;=========== main routine
(defun c:ConvexHull2D () ;( / ptlist hull pts p1
p3 2pi)
(setq 2pi (* 2 pi))
(setq *cmdecho (getvar
"cmdecho"))
(setvar "cmdecho" 0)
(command "._undo"
"_begin")
(setq hull nil)
(setq lines (ssadd))
(getPointList)
(getNEWSPoints)
(setq startTime (*
86400 (getvar "tdusrtimer")))
(prunePoints)
(setq
p1 eastPt)
(setq hull (cons p1 hull))
(setq p3 (list (car
p1) (1- (cadr p1))) temp p3)
(setq prevang (angle p1
p3))
(while (not (equal p3 eastPt)) ;;i.e., continue until
closure
(findMinAngle)
);while
(setq endTime (* 86400 (getvar "tdusrtimer")))
(command "pedit" (entlast) "_join" lines "" "_x")
(command
"._redraw")
(command "._undo" "_end")
(setvar "cmdecho"
*cmdecho)
(princ (strcat "elapsed time: " (rtos (- endtime
startTime))))
(princ)
);defun
(defun c:ch2d ()
(c:ConvexHull2d))
run.")
(princ)
Bill,
This is my 3rd try at responding.
This time, I won't attach the drawing (the server may be rejecting it)
of scattered points.
Your routine draws single lines
through the outermost points, then halts at the following line:
lines "" "_x")
Len
"Bill Gilliss" <
message
href="news:6095635@discussion.autodesk.com">news:6095635@discussion.autodesk.com...
Fatfreek wrote:
Bill,
This is my 3rd try at responding. This time, I
won't attach the drawing (the server may be rejecting it) of scattered
points.
Your routine draws single lines through the
"_x")
Len
Len
One more time -- we must have different setting for PEDITACCEPT. The
attached should take care of that.
Bill
Bill,
It went through without a hitch this
time, producing a polyline that connected points on the periphery of a
pattern of points.
Not knowing what your scheme is, it
appears that it can be likened to a board with a bunch of pins
protruding; then taking a string and simply wrapping that string
around the outermost pins. Is that a correct assessment?
Len
