Visual LISP, AutoLISP and General Customization
Keyboard shortcuts
5 REPLIES 5
esfransen
634 Views, 5 Replies
Keyboard shortcuts
All,
I have had keyboard shortcuts set for 2010 and earlier for osnap input such as SHIFT+S for insertion, SHIFT+E for endpoint, etc.  In 2011 I can use these once and then it just gives me the capital letter in the command line.  Any idears on what's gooing on?
Eric
5 REPLIES 5
esfransen
in reply to: esfransen
I just discovered this:  When I am not in a command and I press SHIFT+A for nea snap I get nea returned at the command line but while in the comand, I get sometimes, the first nea but not the next.
No comnad active gets this:
Command: nea Unknown command "NEA".  Press F1 for help.
Command: ins Unknown command "INS".  Press F1 for help.
Command: endp Unknown command "ENDP".  Press F1 for help.
Command: cen Unknown command "CEN".
In a command I get this:
Command: l LINE Specify first point:   Eendp (Pressing SHIFT+E for endp)
Invalid point.
Invalid point.
Invalid point.
M_Hensley
Why don't you try switching from SHIFT + to CTRL + for shortcuts? They work better that way.
TomBeauford
SHIFT+E works fine with 2011 on my computer.  They need to remain set up as Temporary Override Keys.  SHIFT+E is the default for endpoint and SHIFT+C for center.  Object Snap Override : Insertion is listed, but you need to set the key combination to use it.  Try not to change key combinations already assigned to a function to keep standard one functional.  Just like ENDP, INT, INS, etc... Temporary Override Keys should only work when a command is expecting a point.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
esfransen
in reply to: TomBeauford
So it sounds llike I need to remove the keyboard short cuts that I had in place prior to migration.  Are the Temporary override keys on automatically or is the a system variable that I need to set?
TomBeauford
Check out: http://forums.autodesk.com/t5/AutoCAD-2006/OSNAPOVERRIDE/td-p/1299607
By default they should be on.  To use endpoint while in the line command press and hold SHIFT+E while snaping.  Kinda nice to be able to use the same keyboard shortcut for different things in different situations.  There's only so many key combinations available.
2023
”Boost
