Solved by JGAo1. Go to Solution.
@JGAo1 wrote:Hi, I was wondering if anyone has developed or knows of a tool .... the width of mtext boxes have not been compacted down to the width of the text.
Search this forum for "Mtext Box" or "Mtext Boxes" -- you'll find several threads on the subject.
My apologies for not monitoring this thread more closely. Thanks to all who showed interest .
I'm pleased to report that the routine FX.lsp from http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/MText-Set-Limits-Box-to-minimum/m-p/1... works fine without a problem for both ANNOTATIVE & normal text.
It will change the width to the longest line of text in the mtext box. Now I just need it to change the height...
