Visual LISP, AutoLISP and General Customization
Is there a combination extension & perdendicular?
4 REPLIES 4
draftsdi
228 Views, 4 Replies
I am looking for a lisp that would work similar to the ‘extension’ object snap. Kind of a combination of extension and perpendicular where you could select a point (endpoint, midpoint) on a line/polyline traverse the line a user specified distance (similar to the extension object snap) then specify a perpendicular distance to locate the beginning point of the object to be drawn.
4 REPLIES 4
marko_ribar
in reply to: draftsdi
Hi, draftsdi...
Just align UCS, so that X axis is pointing thowards extension and coordinate origin is at the end of aligned entity... Then you can simple use LINE command or similar, and type for first point
"_non" @extension in X dir,extension in Y dir... ("_non" @110.0,75.0) or ("_non" @110.0,-75.0)...
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
draftsdi
Thanks for your response but I don't want to have to constantly change UCS and it's too much typing. I want something that will do the work for me.
marko_ribar
Do you happen to know that you can make lisp that will follow your inputs, avoiding to type commands that are needed for that specific operation?
marko_ribar
in reply to: marko_ribar
(defun c:pp ( / pt ptw )
  (command "_.ucs" "_ob")
  (while (> (getvar 'cmdactive) 0) (command "\\"))
  (setq pt (getpoint "\nSpecify point in changed UCS : "))
  (setq ptw (trans pt 1 0))
  (command "_.ucs" "_p")
  (setvar 'lastpoint (trans ptw 0 1))
  (princ)
 Just load pp.lsp, type pp at command prompt, pick curve entity end point, and specify coordinates... After pp has finished, use command you want - like "LINE" or similar and when asked for first point specify @ symbol and hit ENTER... That's it point was saved into 'lastpoint sysvar...
HTH, M.R.
”Boost
