is it possible? i need because i get the base point and I start drawing from him.
thanks¡¡¡
Solved by andresep82. Go to Solution.
I'm not so sure, but I think that, if any of group codes 41 42 43 is negative, than block was mirrored.
One thing which is confusing to me is that, if block was mirrored two times, than group code is going to be positive again.
Maybe you can try something like this:
(setq xscale (cdr (assoc 41 block))) (setq yscale (cdr (assoc 42 block))) (setq zscale (cdr (assoc 43 block)))
(minusp (min xscale yscale zscale))
Hope this will help you...
ok....i try to explain....
when you insert a block and you do a mirror to him his base point change.....
and when i do....
pt1 (cdr (assoc 10 (entget bloque) ))
(setq pt2 (polar pt1 (/ (* giro pi) 180.0) (+ parametro1 0.10))
if block has a mirror pt2 draw in correct direction....
yeah¡¡¡¡¡ tharwat
if is possitive do not have mirror, if is negative have a mirror and if you do 2 mirror is possitive, 3 mirror negative.....
thanks¡¡¡¡¡¡¡
@dicra wrote:... if any of group codes 41 42 43 is negative, than block was mirrored.
... if block was mirrored two times, than group code is going to be positive again.
(minusp (min xscale yscale zscale))....
You can account for the possibility of two negative scale factors meaning the Block is not mirrored, by changing one function:
(minusp (* xscale yscale zscale))
