i dimension in plan side.The same dimension how to automatically show the elevation side ( not for copy command) .
when i pick the points in dimension ,automatically show the elevation side ?
AutoCAD does not provide a command to Dimension both a Plan view and an Elevation view.
Typically in contstruction, we would show different dimensions in each view since the Plan view is more about horizontal measurement and the Elevation view is more about vertical measurements. If you want to see a single dimension for both views I would do a 3d View and dimension it on that view.
