Hi
I have a few .dwgs (test1 and test2) that i want to insert as xrefs. So far with the help of other autolisp on the site i have come to this :
(defun C:MultipleXr ( / myxref1 myxref2) ; define the function
(setvar "ctab" "Model") ; move to modelspace
(setvar "clayer" "0") ; set the current layer to 0
(command "ucs" "w")
(setq myxref1 (findfile "C:\\Dropbox\\Acad stuff\\Test\\Test1.dwg")
myxref2 (findfile "C:\\Dropbox\\Acad stuff\\Test\\Test2.dwg")
);; end steqs
(foreach myxref (list myxref1 myxref2)
(command "-xref" "Overlay" myxref "0,0,0" "1" "1" "0")
);foreach
(princ)
It does the job but if i run the command one more time i end up with the same xrefs on top of eachother.
I was thinking about creating some kind of search function to see if the xref is already in the my parent .dwg . Maybe using "ssget" to create a list and using "if" but .......
I realy have to warn you that i am pretty new to autolisp but i am weling to learn.
Solved by hmsilva. Go to Solution.
Something like this perhaps.
(defun C:MultipleXr (/ ENT HND I LST MYXREF MYXREFS OBJ SS XREFLST); define the function (setq myxrefs '("C:\\Dropbox\\Acad stuff\\Test\\Test1.dwg" "C:\\Dropbox\\Acad stuff\\Test\\Test2.dwg")) (foreach xref myxrefs (if (findfile xref) (setq xreflst (cons xref xreflst)) );; if );; foreach (if xreflst (progn (if (setq ss (ssget "_X" '((0 . "INSERT")))) (progn (repeat (setq i (sslength ss)) (setq hnd (ssname ss (setq i (1- i))) ent (entget hnd) obj (vlax-ename->vla-object hnd) );; setq (if (vlax-property-available-p obj 'Path) (if (findfile (vla-get-path obj)) (setq lst (cons (cdr (assoc 2 ent)) lst)) );; if );; if );; repeat (setvar "ctab" "Model"); move to modelspace (setvar "clayer" "0"); set the current layer to 0 (command "ucs" "w") (if lst (foreach xref xreflst (if (not (member (vl-filename-base xref) lst)) (command "-xref" "Overlay" xref "0,0,0" "1" "1" "0") );; if );; foreach (foreach xref xreflst (command "-xref" "Overlay" myxref "0,0,0" "1" "1" "0") );; foreach );; if );; progn );; if );; progn );; if (princ) );; MultipleXr
HTH
Henrique
Tank you for the quick reply but i doesnt seem to work.
I load it up but when i run the command nothing hapens.
I wish i could say more but i have to say i understand maybe half of it.
Sorry Mihai,
the code had a typo!
I have commented the code to facilitate its comprehension.
The code is untested, I don't have AutoCAD in this laptop...
EDIT: after reread the code, I found an error, I think it is already fixed...
(defun C:MultipleXr (/ ENT HND I LST MYXREF MYXREFS OBJ SS XREFLST); define the function ;; sets a list with your xref names (setq myxrefs '("C:\\Dropbox\\Acad stuff\\Test\\Test1.dwg" "C:\\Dropbox\\Acad stuff\\Test\\Test2.dwg" ) );; test if find each file (foreach xref myxrefs (if (findfile xref) ;; if find, create a list with the xrefs (setq xreflst (cons xref xreflst)) );; if );; foreach ;; if found xref list exist (if xreflst (progn (setvar "ctab" "Model"); move to modelspace (setvar "clayer" "0"); set the current layer to 0 (command "ucs" "w") ;; try to select all inserts (if (setq ss (ssget "_X" '((0 . "INSERT")))) (progn ;; if exist inserts (repeat (setq i (sslength ss)) ;; step thru the selection set (setq hnd (ssname ss (setq i (1- i))) ent (entget hnd) obj (vlax-ename->vla-object hnd) );; setq ;; to test if the insert have the Path propertie (xref) (if (vlax-property-available-p obj 'Path) ;; if is a xref create a xref exclusion list, ;; with only the xref name, not path or extension (setq lst (cons (cdr (assoc 2 ent)) lst)) );; if );; repeat ;; if the exclusion list exist (if lst ;; test the if the xref to overlay don't ;; exist in the exclusion list (foreach xref xreflst (if (not (member (vl-filename-base xref) lst)) ;; if not member, do the xref command (command "-xref" "Overlay" xref "0,0,0" "1" "1" "0") );; if );; foreach );; if );; progn ;; if don't exist inserts ;; do the xref command to all the list elements (foreach xref xreflst (command "-xref" "Overlay" xref "0,0,0" "1" "1" "0") );; foreach );; if );; progn );; if (princ) );; MultipleXr
HTH
Henrique
Thank you very much for your help.
I have done some testing and works like a charm
One thing i had to do put the list components from setq myxref on a row with blankspace between.
Amazing that's all that i can say.
