I found this LISP code that can insert a block at coordinates from an ASCII.
(defun c:universal( / file f a osmode);PointsToBlocks (while (not file) (setq file (getfiled "Input file" "coords" "txt" 4)) ) (setq f (open file "r") osmode (getvar "OSMODE") ) (setvar "OSMODE" 0) (while (setq a (read-line f)) (command "._insert" "block1" a 1 1 0) ) (setvar "OSMODE" osmode) (princ)
What I want to be able to do is insert blocks from an ASCII and also set the x-, y-, and z-scales.
For example, I have these lines in ASCII, the data points refer to X position, Y position, Z position, X scale, Y scale, and Z scale.
30.593589,21.274607,26.235255,0.172826,0.766324,0.066442
30.710182,21.379792,27.054248,0.130816,0.700035,0.043114
Thank you in advance for your help, I am a beginner.
Here is a relatively simple example:
;; Insert Block - Lee Mac ;; Inserts a selected block at all points in a given comma-delimited text file ;; with format x,y,z,sx,sy,sz (defun c:insblk ( / *error* blk des itm lst spc txt ) (defun *error* ( msg ) (if (= 'file (type des)) (close des) ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (cond ( (null (setq txt (getfiled "" "" "txt" 16)))) ( (null (setq blk (getfiled "Select Block to Insert" "" "dwg" 16)))) ( (null (setq des (open txt "r"))) (princ "\nUnable to open the selected file for reading.") ) ( (progn (while (setq itm (read-line des)) (if (and (apply 'and (setq itm (mapcar 'distof (LM:str->lst itm ",")))) (= 6 (length itm)) ) (setq lst (cons (append (list (mapcar '(lambda ( a b ) a) itm '(x y z))) (cons blk (cdddr itm)) '(0.0) ) lst ) ) ) ) (setq des (close des)) (null lst) ) (princ "\nNo valid data found in selected file.") ) ( (setq spc (vlax-get (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))) (LM:startundo (LM:acdoc)) (foreach itm lst (apply 'vlax-invoke (vl-list* spc 'insertblock itm))) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; String to List - Lee Mac ;; Separates a string using a given delimiter ;; str - [str] string to process ;; del - [str] delimiter by which to separate the string (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) (vl-load-com) (princ)
The above could be optimised for better performance if the block is non-attributed.
