My AutoLISP is a bit rusty so I apologize if this has an easy answer.
I'm trying to write a routine that lets the user select block A and then inserts block B (a tag) using block A's name and the (only) attribute. I've managed to extract the first block's name using:
(setq ent (nentsel))
(setq blk-name (vla-get-EffectiveName (vlax-ename->vla-object (last (last ent)))))
But when I try to insert the block, I can't get block A's name (as returned by blk-name) as the attribute text using
(Command -insert _tag-part 0,0,0 48 48 0 blk-name)
it fails. I think the attribute parameter (blk-name) is causing the problem because it's not in the form of a string. Any suggestions to get this to work?
Jon
Solved by _Tharwat. Go to Solution.
For your first code to get the real name of the selected block ..
Try ...
(setq blk-name (vla-get-EffectiveName (vlax-ename->vla-object (car ent))))
Thanks, but when I use
and pick the block "breakline it returns "Select object: ; error: ActiveX Server returned the error: unknown name:
EffectiveName"
When I use
it returns""breakline"". Is there something going on that I'm not seeing?
Jon
You should add the following code to your file and load it to activate the Active x codes .
(vl-load-com)
I have just noticed that you are using the function *nentsel* which enter a definition and it is not the proper function for you needs , so just use function *entsel* instead of *nentsel*
Thanks, that helped a lot. My code needs to be fleshed out but this helped.
Thanks again,
Jpn
