This seems the best thread to possibly get some help.
I am running AutoCAD 2015 SP2 and whenever VisualLISP calls:
(vlax-get-or-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2)))
I get an "Automation error. Description not provided." Repaired, Reinstalled, Uninstall/Reinstall, Uninstall/Delete all AutoCAD folders/Reinstall. Nothing seems to help. And it worked before today.
Any chance you guys run into this?
Thanks for any help.
Hi guys,
It is OK If the file is on c: but I am wondering why is not working if the file is on the server?
I get this error: Error: Automation Error. Description was not provided
Thanks!
Marcelo
I solved this error by changing the path from:
K:/Folder/Folder/.../Library1.dwg
to:
K://Folder//Folder//...//Library1.dwg
Double // is the problem, it seems for Server Locations...
Or K:\\\\Folder\\\\Folder\\\\...\\\\Library1.dwg the dbl dbl back bracket will get around problems sometimes of directory having a space in name when using a server name note also the dbl bracket for sub directory as they would normally only have one forward slash. Hope that makes sense.
