Visual LISP, AutoLISP and General Customization
*Moshe
Message 1 of 5 (52 Views)
Insert and Remove Pull-Down Menus
52 Views, 4 Replies
01-18-2006 12:15 AM
Have you notice? when inserting a custom pulldown menu
between ACAD pulldowns menu [like (menucmd "P6=+MyCUI.MenuName")],
the CUI tree pane does not reflect the change, How come?
Is this normal or bug?!
Moshe
*R. Robert Bell
Message 2 of 5 (52 Views)
Re: Insert and Remove Pull-Down Menus
01-18-2006 09:41 AM in reply to: *Moshe
FWIW, I removed all coding that did that sort of thing and went to using
workspaces instead.
R. Robert Bell
"Moshe" wrote in message
news:5062065@discussion.autodesk.com...
Moshe
*Moshe
Message 3 of 5 (52 Views)
01-18-2006 12:35 PM in reply to: *Moshe
Hi Robert,
Are you suggesting to define a new workspace from my custom menu file
(contains one popup) and set it current each time i need a command and
back to acad.cui?
Do you call this efficiency at work?
Thank you for your reply.
Moshe
"R. Robert Bell" wrote in message
news:5062600@discussion.autodesk.com...
workspaces instead.
R. Robert Bell
Moshe
Distinguished Contributor
jlspartz
Message 4 of 5 (52 Views)
01-18-2006 12:48 PM in reply to: *Moshe
I had to set up both. I have a company profile workspace "just in case", and I have a lisp routine that will populate the menus back to the original, in the event someone really messes things up. I hate the new customize screen and I notice it put grabage code into my menus, or leave remnants behind of things that I told it to delete and don't show up in the in the customize menu. I avoid the thing and still write it as an mns and then when loading it creates it into a cui, which is a lot cleaner than going through the customize menu. But, to see the contents of the other cuis in the customize screen, I had to open the cuis through the customize screen.
*R. Robert Bell
Message 5 of 5 (52 Views)
01-18-2006 01:44 PM in reply to: *Moshe
Click to select a "add menu to bar item" vs. click to select another
workspace seems the same to me.
R. Robert Bell
news:5062871@discussion.autodesk.com...
Hi Robert,
back to acad.cui?
Post to the Community
New Post
Need installation help?
