I have this on my pulldown menus by
mistake
I belive that I have a toolbar item of the exact
same title as the pulldown title
so the cui thinks its the same thing and pops in
the icon
I too only edit the .mnu
[img src="@108759"]
[->Modify]
[Change
Elevation
\tCE]^C^C^P(if (not c:CE)(load "ChangeElevation.lsp"))^P CE
[Offset
Elevation
\tOE]^C^C^P(if (not c:OfElev)(load "OFELEV.LSP"))^P OfElev
[Set
sequential elevations ]^C^C^P(if (not
c:SETELEV)(load "SETELEV.LSP.lsp"))^P SETELEV
[Change
Aligned Dim to Rotated ]^C^C^P(if (not c:DimAlign2Rotate)(load
"DimAlign2Rotate.lsp"))^P DimAlign2Rotate
[Change layer
color/linetype\tCC]^C^C^P(if (not Chlaycolt)(load "chlaycoltr16.vlx"))^P
Chlaycolt
[Add Point to
Spline
]^C^C^P(if (not c:SplineAddPoint)(load "SplineAddPoint.lsp"))^P
SplineAddPoint
[Inverse
Polyline ;
]^C^C^P(if (not c:IPOLY)(load "IPOLY.lsp"))^P IPOLY
[Reverse
line/pline/arc/text ]^C^C^P(if (not c:reverse)(load
"reverse.lsp"))^P reverse
[<-Flip
Dimension &nbs p;
]^C^C^P(if (not c:DIMFLIP)(load "DIMFLIP.lsp"))^P DIMFLIP
***TOOLBARS
**CB Civil
[_Toolbar("C::B
Civil", _Top, _Show, 2, 2, 1)]
[_Button("Change
Elevation &nbs p;
", "ChElev.bmp",
"ChElev.bmp")
[_Button("Change
layer color/linetype ", "ChLayColorLinetype.bmp",
"ChLayColorLinetype.bmp")]^C^C^P(if (not Chlaycolt)(load "chlaycoltr16.vlx"))^P
Chlaycolt
[_Button("Change Aligned Dim to Rotated", "ChangeToRotatedDim.bmp",
"ChangeToRotatedDim.bmp")]^C^C^P(if (not c:DimAlign2Rotate)(load
[_Button("Label
Elevation &nbs p;
", "LabelElevation.bmp",
"LabelElevation.bmp") ]^C^C^P(if (not
c:LElev)(load "LabelElev.lsp"))^P LElev
[_Button("Label
Slope &n bsp;
", "LabelSlope.bmp",
"LabelSlope.bmp") &n bsp;
]^C^C^P(if (not c:LSlope)(load "LabelElev.lsp"))^P LSlope
[_Button("Offset
Elevation &nbs p;
", "OffsetElevation.bmp", "OffsetElevation.bmp")
[_Button("2 Point
Rotated Dimension ", "RotatedDimension.bmp",
"RotatedDimension.bmp") ]^C^C^P(if (not c:2pdimrot)(load
"2pdimrot.lsp"))^P 2pdimrot
Dave
right, but I mentioned
that I want to stick with .mnu only.
I know my question might have sounded
like a total beginner issue, but its actually not, I know the CUI well by
now.
I am asking how to do that purely in the .mnu.
One answer is to
simply make a toolbar with exactly the same commands as the pulldowns.
Only
issue is then I have to maintain the pulldown item, and the button because any
differences in the macros will keep
the picture from being assigned to the
pulldown item...
tdaniel14 <>
|>When you click on your item
in the CUI, you should be able to add the .bmp name to the images portion of the
Properties window. Example: "Small image" -
northarrow.bmp. Assuming you have a bmp named northarrow and you set a
reference to its location, this should give you an image.
James
Maeding
Civil Engineer and Programmer
jmaeding - athunsaker -
com
