Visual LISP, AutoLISP and General Customization
If statements
8 REPLIES 8
Message 1 of 9
1CAlexander1
396 Views, 8 Replies
If statements
How do I get multiple if statements to work within the same LISP routine? Or is this not possible? If not, what is a good work around?
8 REPLIES 8
Message 2 of 9
in reply to: 1CAlexander1
Silomethis,
COND
W. Kirk Crawford
Tularosa, New Mexico
"silomethis" wrote in message news:5699223@discussion.autodesk.com...
Message 3 of 9
1CAlexander1
I'm not sure if I was using COND correctly the time I attempted to use it. I used it something like this.
(cond
(if
true
false
);if
(if
true
false
);if
);cond
I'm sure this was incorrect usage though.
Message 4 of 9
EC-CAD
Here is an example.
Usage: COND
(cond
( (= X 1)
(setq z 0)
(.. do more stuff)
( (= X 2)
(setq z 1)
(.. do more stuff)
T
); end cond
Bob
Message 5 of 9
Tom Smith
See http://afralisp.net/lisp/conif.htm
You can use all the ifs you want, but IMO lots of ifs are usually a result of poor program design. Cond will usually let you do same thing more clearly and with less code.
Message 6 of 9
1CAlexander1
Thanks all for the help and the great link. Got it working. 🙂
Message 7 of 9
silomethis said the following on 8/23/2007 2:01 PM:
> around?
This is not to say that (cond) is not a better method, but if you really
want to use multiple (if) statements, here is an example:
(if (= 1 1)
(if (= 2 2)
(if (= 3 3)
(if (= 4 5)
(if (= 6 6)
(princ "all true")
Which fails of course on the 4th (if) statement.
R.K. McSwain
http://rkmcswain.blogspot.com
Message 8 of 9
Tom Smith
A cleaner way to do the same sequential test would be:
(and
(= 1 1)
(= 2 2)
(= 3 3)
(= 4 5)
(= 6 6)
(princ "all true")
Message 9 of 9
Tom Smith said the following on 8/25/2007 1:05 PM:
> (and
> (= 1 1)
> (= 2 2)
> (= 3 3)
> (= 4 5)
> (= 6 6)
> (princ "all true")
True, but since the OP asked about "multiple if statements", I was just
showing that it *can* be done.
Just for grins, I ran both versions, using the same timer for 1,000,000
iterations each.
The (if) version averaged about 2.55 seconds
The (and) version averaged about 2.45 seconds.
R.K. McSwain
”Boost
