Visual LISP, AutoLISP and General Customization
if or cond statements
12 REPLIES 12
Message 1 of 13
864 Views, 12 Replies
im needing to put an if statement, or cond (not sure which one or both) in and have no idea how to
make it work.
i tried this
(if ((< px1 qx1)(< py1 qy1)) sym1)) ;draw symbol up and left
(if ((> px1 qx1)(< py1 qy1)) sym2)) ; draw symbol up and right
(setq sym1 (command "_.pline" ti vert horz "")) ;draws slope symbol
(setq sym2 (command "_.pline" ti vert2 horz2 ""))
could someone show me how to actually set this up right. am I way of base?
dont laugh to hard and when I get this routine up and runnin I will share it
Dave C. Johnson
12 REPLIES 12
Message 2 of 13
make it work.
i tried this
No laughing. We all started somewhere.
Since the (<py1 qy1) was the same in each IF statement, you don't
need to include it. If it does need to stay for some reason, use
(if (and (< px1
qx1) (< py1 qy1) )
(if
  (< px1 qx1)
  (command "_.pline" ti vert horz "")   ;draw symbol up and left
  (command "_.pline" ti vert2 horz2 "") ;draw symbol up and right
or
(if
  (< px1 qx1)
  (sym1) ;draw symbol up and left
  (sym2) ;draw symbol up and right
(defun sym1 (command "_.pline" ti vert horz ""))   ;;note DEFUN, not
SETQ
(defun sym2 (command "_.pline" ti vert2 horz2 ""))
Message 3 of 13
As a general rule, if there is a binary yes/no choice, like "Line or
Polyline?" use IF.
If the result of one decision determines the next decision, use nested
IF's.
If there are multiple choices, like "Line, Polyline, Circle, or
Ellipse?"), use COND.
Your routine did not say what to do if px1 = qx1.
My IF solution treats that the same as (> px1 qx1)
COND could have been used to deal with this undefined condition on its
own, or the same as either of the other two.
(cond
(< px1 qx1) (sym1))
  ( (> px1 qx1) (sym2))
  ( T           (sym3))  ;;this catch all is executed if no condition
                         ;;that precedes it is true.
Message 4 of 13
Oops.
SETQ
should be
(defun
sym1 () (command "_.pline" ti vert horz ""))   ;;note DEFUN, not
SETQ
(defun sym2 () (command "_.pline" ti vert2 horz2 ""))
Message 5 of 13
thanks Bill. this will get me moving again. the if/cond are still confusing to me but I will come
around.
Dave C. Johnson
Message 6 of 13
The exemple I use when trying to explain the COND statement is about colors.
If in real life everything was black and white, one could use an IF
(if (= color "Black")
(do_black);;; true branch
(do_white);;; false branch, i.e. color = white
No, in real life we have more than black and white, so for more than one
possible truth, we could nest more IFs, but some smart people thought about
some other function, which in LISP is called COND.
(cond
( (= color "red");;; if this is true
(do_red)
( (= color "yellow");;; if this is true
(do_yellow)
( (= color "green");;; if this is true
(do_green)
( (= color "blue");;; if this is true
(do_blue)
(T (do_whatever_else_color);;; if eveything else is true
The cond function accepts any number of lists as arguments. It evaluates the
first item in each list (in the order supplied) until one of these items
returns a value other than nil. It then evaluates those expressions that
follow the test that succeeded. It is common to use T as the last (default)
test expression.
Return Values
The value of the last expression in the sublist. If there is only one
expression in the sublist (that is, if result is missing), the value of the
test expression is returned. If no arguments are supplied, cond returns nil.
HTH
"djohnson" a écrit dans le message de news:
6107244@discussion.autodesk.com...
around.
Dave C. Johnson
Message 7 of 13
To expand a little on what Some Buddy replied, and make more explicit something he didn't quite say
outright about one of (cond)'s benefits:
When you have more than one possibility to check, a big advantage of (cond) over (if) is that (cond)
*doesn't even bother to look at* any conditions after the first one that is satisfied. If you check
for multiple conditions with multiple (if) functions, like this:
{code}
(if (= color "red") (...do the red thing...))
(if (= color "yellow") (...do the yellow thing...))
(if (= color "green") (...do the greeb thing...))
(if (= color "blue") (...do the blue thing...))
{code}
it will work, but it will test for *all* of those possibilities, regardless of whether it finds any
of them satisfied. If the color is "red," it will do the red thing, but then it will also, and
unnecessarily, go on to check whether the color is any of those other possibilities. That will be a
complete waste, because none of them are going to be satisfied if the color is "red."
But if you use (cond), like this:
{code}
(cond
((= color "red") (...do the red thing...))
((= color "yellow") (...do the yellow thing...))
((= color "green") (...do the green thing...))
((= color "blue") (...do the blue thing...))
(T (...do the anything-else thing)); [with or without this]
); end cond
{code}
then it will only check *until it finds a true condition*, and ignore the rest. If the color is
"red," it will do the red thing, and then *go to the end* of the (cond) function, and continue with
whatever is next, without bothering itself to check for the other possibilities which won't be
satisfied.
Also, if you want an anything-else thing to be done if the color isn't any of those four, then it's
a lot more complicated with (if) functions. You would probably need an additional (if) function,
along with the ones above, something like:
{code}
(if
(not
(or
(= color "red")
(= color "yellow")
(= color "green")
(= color "blue")
); end or
); end not
{code}
or, a somewhat shorter way:
{code}
(if
(not
(member color '("red" "yellow" "green" "blue"))
{code}
Shorter, but still a lot more code than necessary if you use the (cond) approach instead.
Kent Cooper
"djohnson" wrote...
.... the if/cond are still confusing to me but I will come
around.
Message 8 of 13
From my previous message:
"It evaluates the first item in each list (in the
returns a value other than nil."
And anyway, I think that one who wants to
learn about LISP should read a little more by him self, than expecting
people here to write pages of explanations. What I think is that putting people
on the rails is enough, there is no need to push their train. But then again,
this is just me.
outright
*doesn't even
If you check
this:
{code}
(if (=
greeb thing...))
thing...))
{code}
of them satisfied.
this:
{code}
(cond
thing...))
  ((= color "blue")
or without this]
); end cond
{code}
satisfied.
Also, if
then it's
something like:
{code}
(if
  (not
(or
      (= color
"red")
      (= color
"yellow")
      (= color
"green")
      (= color
"blue")
    ); end or
  ); end not
  (...do
{code}
way:
{code}
(if
  (not
    (member color
thing)
{code}
Kent
Cooper
"djohnson" wrote...
me but I will come
around.
Message 9 of 13
thanks guys that does help me and I really do appreciate it. I will keep hammering on this code and
post it when I get it done, which will be a while because I keeping running into stuff I had not
thought of. 2 steps forward 5 steps back 🙂
Dave C. Johnson
Message 10 of 13
You're welcome Dave 🙂
6107406@discussion.autodesk.com...
Dave C. Johnson
Message 11 of 13
> make it work.
> i tried this
Others have already talked about IF and COND, I'd like to comment on two
beginner's mistakes your initial code is showing:
1. The parentheses must balance. Unless you are closing some larger
piece of program not shown here, you have one closing parenthesis too
much on each line.
2. Unlike many other programming languages, you may not add arbitrary
parentheses anywhere you like to combine clauses. You need to use some
special operators to connect stuff, for example AND, OR etc. PROGN is
also often useful, though meaningless in a test.
(if (and (< px qx1)(< py1 qy1)) sym1)
Message 12 of 13
thanks Martti
I do seem to have trouble counting the parens, but I do know they need to equal.
Im still struggling with the special operators but can see how vital they are to getting things
accomplished in the routine.
Dave C. Johnson
Message 13 of 13
djohnson wrote:
> thanks Martti
The trick with counting parens is getting the computer to do that for
you: find an editor that can show the matching parens and can indent the
code according to syntax. Professionals read Lisp code based on the
indentation, not the parens.
The best editor for Lisp work I know is GNU Emacs, but even VLIDE is
better than nothing.
”Boost
