Visual LISP, AutoLISP and General Customization
If entity not found dont show error message
3 REPLIES 3
JCprog
265 Views, 3 Replies
Hello everyone Smiley Happy
I found this great code by Kent which toggles layer on/off and works great except it shows error (bad argument type: lentityp nil) when one of the layers dont exist. How can I make it ignore the error (not print in command line)? Please help.....Thanks in advance!
(defun C:demo ()
	(layertoggle "myLayer01")
	(layertoggle "myLayer02")
(defun layertoggle (layname / laydata) (setq laydata (entget (tblobjname "layer" layname)) laydata (subst (cons 70 (boole 6 (cdr (assoc 70 laydata)) 1)) (assoc 70 laydata) laydata ) ) (entmod laydata) )
3 REPLIES 3
Kent1Cooper
in reply to: JCprog
@JCprog wrote:
I found this great code by Kent which toggles layer on/off and works great except it shows error (bad argument type: lentityp nil) when one of the layers dont exist. How can I make it ignore the error (not print in command line)? ....
  (if (tblsearch "layer" layname); does the Layer exist?
    (progn ; then
      (setq
        laydata (subst (cons 70 (boole 6 (cdr (assoc 70 laydata)) 1)) (assoc 70 laydata) laydata)
      (entmod laydata)
    ); progn
  ); if
Kent Cooper, AIA
JCprog
in reply to: Kent1Cooper
That works perfectly! Thanks Kent! Smiley Very Happy
Lee_Mac
in reply to: JCprog
FWIW, there is no need to use both tblsearch and tblobjname, since tblobjname will return nil if the layer doesn't exist, e.g.:
(defun layertoggle ( lay / dxf )
    (if (setq lay (tblobjname "layer" lay))
        (entmod
            (setq lay (entget lay)
                  dxf (assoc 70 lay)
                  lay (subst (cons 70 (boole 6 (cdr dxf) 1)) dxf lay)
”Boost
