The_Caddie
Message 1 of 3 (294 Views)
If else when checking for registry key
294 Views, 2 Replies
10-12-2012 01:06 AM
I want to create a registry key using lisp but only if it dost already exist I know how to use the IF else function and how to create a registry key using lisp but not sure on how to check for the existence of a registry key with in a lisp program?
pbejse
Message 2 of 3 (291 Views)
Re: If else when checking for registry key
10-12-2012 01:19 AM in reply to: The_Caddie
vl-registry-read
vl-registry-write
vl-registry-delete
or
GETENV and SETENV me thinks
HTH
bobdobbs
Message 3 of 3 (269 Views)
10-12-2012 01:43 PM in reply to: The_Caddie
I think vl-registry-write will only make the key if it doesn't exist. Or, rather I should say, you will not lose any values already in that key by using vl-registry-write to try to create it.
So, why check first? (Unless you mean a registry "VALUE" or "DATA" and not "KEY")
Example:
Command: (vl-registry-read "HKEY_CURRENT_USER\\TestA")
nil
Key does not exist
Command: (vl-registry-write "HKEY_CURRENT_USER\\TestA")
T
Now it does but has no values
nil
read fails because it looks for a value
Command: (vl-registry-write "HKEY_CURRENT_USER\\TestA" "" "default-value")
"default-value"
I add a value
"default-value"
It reads a value
T
I re-write the key
"default-value"
value is still there
fugetaboutit
