Visual LISP, AutoLISP and General Customization
if condition causes problem calling other lisp
2 REPLIES 2
bart_van_tuyl
261 Views, 2 Replies
I have a lisp which pendant on wether a linetype exists will automatically run or not. I thought that the rule was if a lisp is to call another lisp we do that as follows
(WOBEL)
 as aposed to when its called through the command line as follows
(defun C:WOBEL ()
however with this in mind the following will not work
 (if (null (tblsearch "ltype" "BOUWTEK-01"))
  (WOBEL)
(DEFUN WOBEL ()
(alert "this is where the relating command would be")
 so what have i done wrong?
2 REPLIES 2
hmsilva
in reply to: bart_van_tuyl
(DEFUN WOBEL ()
  (WOBEL)
You must ensure that "WOBEL" function is already loaded when you call it...
HTH
Henrique
Shneuph
If you define the lisp using C:WOBEL (command) you would have to call it with (C:WOBEL).  If you don't use WOBEL as a command define it as Defun WOBEL ( / ...) (function) and call as (WOBEL).
Afralisp page that talks about defun
”Boost
