I have a command that opens a dcl with choices of predefined text strings. It uses getpoint to get two endpoints and then it calculates the middle of those for the text insertion point. It uses point 2 for the rotation of the text.
The problem is that you can not "see" a line when picking points and you do not know the rotation of the new text object. Can anyone add some way of "seeing" the rotation line as you pick pt1 & pt2?
I have attached the code. Go easy on me, I am not a programmer, just a customization lover!
Thanks!!!
