Hello
i want to select blocks on multiple polyline at once with the inserting pont of block.
so he dont want to work;
(defun c:test (/ js fence ss i pl)
(or
(setq js (ssget "_I"))
(setq js (ssget "_P"))
(cond
(js
(sssetfirst nil js)
(initget "Existant Nouveau _Existent New")
(if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
(progn (sssetfirst nil nil) (setq js (ssadd) js (ssget)))
(T (setq js (ssget)))
(cond
(js
(setq fence (listpol(ssname js (setq n (1- n)))))
setq ss (ssget "_F" fence '((0 . "INSERT"))))
(repeat (setq i (sslength ss))
(setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
;;; listpol by Gille Chanteau ;
;;; Returns the vertices list of any type of polyline (WCS coordinates) ;
;;; Argument ;
;;; en, a polyline (ename or vla-object) ;
(defun listpol (en / i p l)
(setq i (if (vlax-curve-IsClosed en)
(vlax-curve-getEndParam en)
(+ (vlax-curve-getEndParam en) 1)
(while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
(setq l (cons (trans p 0 1 ) l))
It may not be the only problem, but one thing I noticed -- the above should be:
(setq ss (ssget "_F" fence '((0 . "INSERT"))))
So thank you
I found another problems but now i don't know where is the probleme.
if you can look.
(defun c:test (/ ename fence ss j pl)
(or
(cond
(js
(sssetfirst nil js)
(if
(eq (getkword
"New"
(setq js (ssadd)
js (ssget)
(cond
(js
(repeat (setq i (sslength js))
(setq ename (ssname js (setq i (1- i)))
fence (listpol ename)
(setq pl
(cons
(cdr (assoc 10
(entget (ssname ss (setq j (1- j))))
pl
;;; Argument ;
(while
(setq l (cons (trans p 0 1) l))
You will likely get "case sensitivity" issues with this code, try looking into the (strcase) function, specifically for these lines of code
(initget "Existant Nouveau _Existent New") (if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: " ) "New" )
I may not be correct but perhaps that will help you.
Gl and thanks.
Using indentation to clarify the left- and right-parenthesis pairs, I find some apparent parentheses issues [I hope I'm correctly interpreting the sequence of events]. You could also pull the definition of listpol fully outside the C:TEST command definition, which would move another of the right parentheses earlier.
(or
); or
(cond [1]
(js ; selection exists implied or previous
(sssetfirst nil js)
(progn ; then
(setq
js (ssadd); not necessary [next line will override]
js (ssget)
); setq
); progn
); if
); js-exists condition
(T ; doesn't exist -- get some
(setq js (ssget))
); doesn't-exist condition
);;;;; END COND [1]
(cond [2]
(js ; selection exists from whichever method from above
(setq
);;;;; END SETQ
);;;;; END REPEAT
(repeat (setq i (sslength ss));;;;; [AS YOU HAD IT, THIS WILL TRY TO BE A VARIABLE NAME]
(setq pl
(cons
(cdr (assoc 10 (entget (ssname ss (setq j (1- j))))))
pl
); cons
); setq
); repeat
); cond [2]
;;; Argument ;
(setq i
(vlax-curve-getEndParam en); then
(+ (vlax-curve-getEndParam en) 1); else
); if
); setq
(while
); while
); defun -- listpol
;;;;;);;;;; MOVED EARLIER
); defun -- C:TEST
@Anonymous wrote:
So was the strcase not needed?
Not in this case. When you use (initget)/(getkword), the returned string is always in the same case combination as where it's listed inside (initget), regardless of the case(s) the User types. Whether they type n or N or ne or NE or nE or Ne or new or New or NEW or nEw or neW or NeW or NEw or nEW, the returned string will always be "New" as in (initget)'s options list.
Command: (initget "New Old")
Command: (getkword "Which? ")
Which? NEW ;; <-- typed
"New" ;; <-- returned
thank you
Just can you explain me what you tell this will try to be a variable name because when i use it the return is this error:
no function definition: LISTPOL
I want to kwon where does she come.
;;; listpol by Gille Chanteau ; ;;; Returns the vertices list of any type of polyline (WCS coordinates) ; ;;; ; ;;; Argument ; ;;; en, a polyline (ename or vla-object) ; (defun listpol (en / i p l) (setq i (if (vlax-curve-IsClosed en) (vlax-curve-getEndParam en); then (+ (vlax-curve-getEndParam en) 1); else ); if ); setq (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i)))) (setq l (cons (trans p 0 1) l)) ); while ); defun -- listpol
right there in the routine
@Anonymous wrote:
... when i use it the return is this error:
I didn't think of that -- it would be a reason to pull the definition of (listpol) outside of the definition of C:TEST. If they are together in a file, once you load it, both will be defined. As it is, I think it's reaching a use of the (listpol) function before it reaches the definition of it. You could also fix it by moving the definition of (listpol), still inside the definition of C:TEST, up to the beginning of it, so that (listpol) is defined before it's used.
