Visual LISP, AutoLISP and General Customization
i need help for bug
10 REPLIES 10
Message 1 of 11
718 Views, 10 Replies
i need help for bug
Hello
i want to select blocks on multiple polyline at once with the inserting pont of block.
so he dont want to work;
(defun c:test (/ js fence ss i pl)
(or
(setq js (ssget "_I"))
(setq js (ssget "_P"))
(cond
(js
(sssetfirst nil js)
(initget "Existant Nouveau _Existent New")
(if (eq (getkword "\nTraiter jeu de sélection [Existant/Nouveau] <Existant>: ") "New")
(progn (sssetfirst nil nil) (setq js (ssadd) js (ssget)))
(T (setq js (ssget)))
(cond
(js
(setq fence (listpol(ssname js (setq n (1- n)))))
setq ss (ssget "_F" fence '((0 . "INSERT"))))
(repeat (setq i (sslength ss))
(setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
;;; listpol by Gille Chanteau ;
;;; Returns the vertices list of any type of polyline (WCS coordinates) ;
;;; Argument ;
;;; en, a polyline (ename or vla-object) ;
(defun listpol (en / i p l)
(setq i (if (vlax-curve-IsClosed en)
(vlax-curve-getEndParam en)
(+ (vlax-curve-getEndParam en) 1)
(while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
(setq l (cons (trans p 0 1 ) l))
10 REPLIES 10
Message 2 of 11
Kent1Cooper
It may not be the only problem, but one thing I noticed -- the above should be:
(setq ss (ssget "_F" fence '((0 . "INSERT"))))
Kent Cooper, AIA
Message 3 of 11
in reply to: Kent1Cooper
So thank you
I found another problems but now i don't know where is the probleme.
if you can look.
(defun c:test (/ ename fence ss j pl)
(or
(cond
(js
(sssetfirst nil js)
(if
(eq (getkword
"New"
(setq js (ssadd)
js (ssget)
(cond
(js
(repeat (setq i (sslength js))
(setq ename (ssname js (setq i (1- i)))
fence (listpol ename)
(setq pl
(cons
(cdr (assoc 10
(entget (ssname ss (setq j (1- j))))
pl
;;; Argument ;
(while
(setq l (cons (trans p 0 1) l))
Message 4 of 11
You will likely get "case sensitivity" issues with this code, try looking into the (strcase) function, specifically for these lines of code
(if
(eq (getkword
"New"
 I may not be correct but perhaps that will help you.
Gl and thanks.
Message 5 of 11
Kent1Cooper
Using indentation to clarify the left- and right-parenthesis pairs, I find some apparent parentheses issues [I hope I'm correctly interpreting the sequence of events].  You could also pull the definition of listpol fully outside the C:TEST command definition, which would move another of the right parentheses earlier.
  (or
  ); or
  (cond [1]
    (js ; selection exists implied or previous
      (sssetfirst nil js)
        (progn ; then
          (setq
            js (ssadd); not necessary [next line will override]
            js (ssget)
          ); setq
        ); progn
      ); if
    ); js-exists condition
    (T ; doesn't exist -- get some
      (setq js (ssget))
    ); doesn't-exist condition
  );;;;; END COND [1]
  (cond [2]
    (js ; selection exists from whichever method from above
        (setq
        );;;;; END SETQ
      );;;;; END REPEAT
      (repeat (setq i (sslength ss));;;;; [AS YOU HAD IT, THIS WILL TRY TO BE A VARIABLE NAME]
        (setq pl
          (cons
            (cdr (assoc 10 (entget (ssname ss (setq j (1- j))))))
            pl
          ); cons
        ); setq
      ); repeat
  ); cond [2]
;;; Argument ;
    (setq i
        (vlax-curve-getEndParam en); then
        (+ (vlax-curve-getEndParam en) 1); else
      ); if
    ); setq
    (while
    ); while
  ); defun -- listpol
;;;;;);;;;; MOVED EARLIER
); defun -- C:TEST
Kent Cooper, AIA
Message 6 of 11
So was the strcase not needed?
Message 7 of 11
Kent1Cooper
Not in this case.  When you use (initget)/(getkword), the returned string is always in the same case combination as where it's listed inside (initget), regardless of the case(s) the User types.  Whether they type n or N or ne or NE or nE or Ne or new or New or NEW or nEw or neW or NeW or NEw or nEW, the returned string will always be "New" as in (initget)'s options list.
Command: (initget "New Old")
Command: (getkword "Which? ")
Which? NEW ;; <-- typed
"New" ;; <-- returned
Kent Cooper, AIA
Message 8 of 11
I see. Thank you for clearing that up for me.
Another kudos incoming!! 😄
Message 9 of 11
thank you
Just can you explain me what you tell this will try to be a variable name because when i use it the return is this error:
 no function definition: LISTPOL
I want to kwon where does she come.
Message 10 of 11
;;; Argument ;
    (setq i
      ); if
    ); setq
    (while
    ); while
  ); defun -- listpol
right there in the routine
Message 11 of 11
Kent1Cooper
@Anonymous wrote:
... when i use it the return is this error:
I didn't think of that -- it would be a reason to pull the definition of (listpol) outside of the definition of C:TEST.  If they are together in a file, once you load it, both will be defined.  As it is, I think it's reaching a use of the (listpol) function before it reaches the definition of it.  You could also fix it by moving the definition of (listpol), still inside the definition of C:TEST, up to the beginning of it, so that (listpol) is defined before it's used.
Kent Cooper, AIA
”Boost
