Visual LISP, AutoLISP and General Customization
i need a lisp to automaticlly add value to existing attribute in all blocks
8 REPLIES 8
Message 1 of 9
armati
675 Views, 8 Replies
hey im using autocad 2013 and i have 2000 blocks called Drain_bore
and they have BORE_NUMBER attribute for example:
720/1/
719/1/
687/1/
while the first 3 digits represent area code and the next digit represent item code
i need a lisp that would automaticlly number all the blocks in my drawing without changing the existing attribute for example:
720/1/1
720/1/2
720/1/3
719/1/1
719/1/2
687/1/1
687/1/2
so basiclly just adding a number in incrementals of +1 after the actual value
please help
8 REPLIES 8
Message 2 of 9
3wood
in reply to: armati
Let's say you have 3 off 720/1, then which one is 702/1/1?
Message 3 of 9
artur_isa
in reply to: 3wood
usually the blocks are always connected (working with water infrastructures)
so i would prefer if i choose the first block and it will automaticlly continue from there like this:
(zero is a manhole and ------- is a connecting line)
0----------------------------0-------------------------0
720/1/1               720/1/2            720/1/3
most of the times i will have something like this
0    540/1/1         0 530/1/1        0 721/1/3
0-------------------------0--------------------------------0                                             0------------------------------0------------------0
| 720/1/1            720/1/2                     720/1/3                                     721/1/1                   721/1/2          721/1/4
0  540/1/2
Message 4 of 9
3wood
in reply to: artur_isa
It looks there is not much logical rule for the number sequence. The numbers follow the pipe line network.
Message 5 of 9
Ajilal.Vijayan
Can you post a sample drawing or part of that drawing to check ?
Message 6 of 9
artur_isa
in reply to: Ajilal.Vijayan
gave an example of street 413
xxxx/yy/zz
xxxx-street code (e.g. 413)
yy- accessory code (0 means manhole)
zz-id number so we can individualize them in data extraction
possible?
Message 7 of 9
Ajilal.Vijayan
Please ignore if you already tried this.
A quick thing in mind is ...have you considered ATTOUT and ATTIN commands from Express tools ?
ATTOUT will give you an output as attached and edit the Manhole name using excel and use ATTIN to bring back the changes in the drawing.
Message 8 of 9
artur_isa
yes i know but the numbering must go in series like first manhole and then the second manhole connected to it on same street
and in excel its pretty random..
Message 9 of 9
Ajilal.Vijayan
Yes if you ATTOUT, have to sort the manhole names in excel or have to select in order from AutoCAD.
Also try this lisp routine.
Spoiler
(vl-load-com)
(defun C:ADDIN ( / base_MH eNAME base_name eNAME EOBJ st_code item_code num tn Sl_Ln)
(setq base_MH (entsel "\nSelect the Base Manhole:"))
(setq base_name nil)
(setq eNAME (car base_MH))
   (setq EOBJ (vlax-ename->vla-object eNAME))
   (if (= (vla-get-hasattributes EOBJ) :vlax-true)
 	(progn
 	  (foreach N (vlax-safearray->list
 		   (variant-value (vla-getattributes EOBJ)))
	    (if (= (vla-get-tagstring N) "BORE_NUMBER")
	      (setq base_name (vla-get-textstring N))
);for each
	  );progn
	  (progn
(alert "No attributes found for this block\n")
     (exit)
	 );progn
     );if
(if base_name
(progn
(setq st_code (substr base_name 1 3));street code
(setq item_code (substr base_name 5 1));item code
(setq num 1);increment
(princ "\nSelect the continous Manholes")
(setq Slctn (SSGET ))
(setq Sl_Ln (sslength Slctn))
(setq tn 0)
(repeat Sl_Ln
(setq Obj (ssname Slctn tn))
(setq EOBJ (vlax-ename->vla-object Obj))
 	(progn
 		   (variant-value
	      (vla-put-textstring N (strcat st_code "/" item_code "/" (itoa num)))
);for each
	  );progn
     );if
(setq tn ( + tn 1))
(setq num ( + num 1))
);repeat
);progn
);if
  );defun
You have to select the First Manhole text and the subsequnet manhole text in order.
”Boost
