Visual LISP, AutoLISP and General Customization
I currently use a tool caled Steamroller, how do I best add a step?
21 REPLIES 21
Message 1 of 22
claimed4all
1153 Views, 21 Replies
I currently use a tool called Steamroller.lsp
I have editited it once to have it ask you before running the operation.
So right now you run the tool
You get a prompt to run the tool
It grabs all the Survey Figure Lines, explodes them
Figures become 3D polylines
3D polylines are flattened and become 2D polylines
My surveyor would love it if the tool had one more step, so it would run like this:
**A copy is made of all 3D polylines and moved to LAYER-XXXXX**
3D polylines (the once not copied to new layer) are flattened and become 2D polylines
Is this possible?  In the realm of a non programmer to do or will I probably be hiring this out?
21 REPLIES 21
Message 21 of 22
hmsilva
in reply to: claimed4all
@claimed4all wrote:
That code right there worked as inteded.  It copied my 3D polylines to layer LAYER-XXXXX and then it took the original 3D polylines and turned them into basic polylines.
The code I've posted 'Steamroller-Modified_V1.lsp' should also work as expected.
Henrique
Message 22 of 22
claimed4all
in reply to: hmsilva
Thanks for your help. I'll give it a shot in a few drawings and see what
shakes. I think I have enough info to alter it slightly if I see an issue.
--Gregory A. Newland
Mobile 989-239-4128
gregnewland@gmail.com
”Boost
