I can run atoms-family and get a list of all symbols, and I have a lisp which searchs through all my lisp files to find something. but I'm wondering if anyone has built a parser that skips through a function and finds all the variables and determines if any are global? Does vlide do something like this?
TDP
if you use the check edit window button in the vlide it will list all the functions and their global variables in the build output window
eg
function is LOAD_LT -> global vars are FNAME and PATH
; === Top statistic:
; Global variables: (FNAME PATH)
; Function definition (with number of arguments): ((LOAD_LT . 0))
; Check done.
1. The Vlide may do what you want, or so implied here:
http://rkmcswain.blogspot.com/2006/07/vlisp-variables.html
only if the "Report statistics during syntax checking" box is checked.
2. In our small group, we use the '*' within a global variable to make them more findable.
And even with that convention, our parser to find local variables within the text of a DEFUN was massive, and undependable.
And the inadvertent global is the worst: making values change improperly because they were reset somewhere else.
Now we belong to the school of minimum globals.
thanks for the reply. I use very few globals - and most of mine store data in an assoc list. I've found a few functions that are rather large where I've missed setting a couple of variables to local....and with 90,000+ loines of code well I want to make a good check. such a parser must be very elegantly written or it becomes unwieldy and bugggy....
thanks for your help on the vlide thing...
Jamie
