Visual LISP, AutoLISP and General Customization
How to (transparently) get out of the viewport back into paper space?
3 REPLIES 3
scot-65
460 Views, 3 Replies
I'm trying to limit the activity inside a paper space's viewport.
Specifically text and dimension objects (our routines) as these layers inside the viewport may be frozen.
How do I pragmatically get out of the viewport back into paper space?
Command: _.PSPACE
Command: cvport
Enter new value for CVPORT <1>:
Command: _.MSPACE
Command: cvport
Enter new value for CVPORT <2>: 1
Cannot set CVPORT to that value.
*Invalid*
Thanks in advance.
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
3 REPLIES 3
Kent1Cooper
in reply to: scot-65
Something as simple as (command "_.pspace") ought to do it, unless I'm misunderstanding.
Kent Cooper, AIA
scot-65
in reply to: Kent1Cooper
I may not have correctly formulated the statement the first time around...
(if (> (getvar "CVPORT") 1) (command ".pspace") );if
Now I have discovered that the subroutine call to check for cvport is placed further down the routine (inside the "main" section and not before the user input part of the program - I.E.: must be placed before getpoint).
Thanks anyways.
scot-65
Scot-65
Ian_Bryant
Hi, if you wish to avoid the command function
e.g. inside a reactor function
or in a function to be used with vlax-add-command
to create a transparent command
you can try the following:
(and
  (= (getvar "TILEMODE") 0)
  (vla-put-Mspace (vla-get-activedocument (vlax-get-acad-object)) 0)
Ian
”Boost
