Visual LISP, AutoLISP and General Customization
How to tell if inside a paperspace's viewport?
7 REPLIES 7
Message 1 of 8
scot-65
2268 Views, 7 Replies
While in paperspace, and I double-click a viewport,
the following is displayed on the command prompt:
Command: _.MSPACE
What variable lets me know that I am now in (the viewport's) model space?
Command: _.MSPACE
Command: tilemode
Enter new value for TILEMODE <0>:
Command: _.PSPACE
Command: tilemode
Thanks in advance.
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
7 REPLIES 7
Message 2 of 8
hmsilva
in reply to: scot-65
CVPORT
1 - no viewport active
Henrique
Message 3 of 8
BlackBox_
This code snippet is a more complete example (one of multiple), of how to identify 'where' you are:
(if (= 1 (getvar 'tilemode))
  ;; modelspace
  (if (= 1 (getvar 'cvport))
    ;; paperspace
    ;; pviewport active
The problem comes from CVPORT not being changed when one switches betwen Model and Layout, as TILEMODE does, which is why one must use a Command reactor to 'trace' after the active space (i.e., Model, Paper, PViewport Active) has changed.
Cheers
"How we think determines what we do, and what we do determines what we get."
Message 4 of 8
scot-65
in reply to: hmsilva
(if (and (= (getvar "TILEMODE") 0)(< (getvar "CVPORT") 2));and
Thanks.
Scot-65
Message 5 of 8
hmsilva
You're welcome, scot-65
Another,
testing for an active viewpot
(if (and (= (getvar "TILEMODE") 0)(/= (getvar "CVPORT") 1));and
Henrique
Message 6 of 8
BlackBox_
... Simpler still:
(< (getvar 'tilemode) 1 (getvar 'cvport))
Message 7 of 8
msarqui
in reply to: BlackBox_
Hi guys,
Just for fun...
(defun c:WhereAmI ()
(if (and (= (getvar "TILEMODE") 1)(= (getvar "CVPORT") 2));and
(princ "\n  ** You are in Model Space **")
);if
(if (and (= (getvar "TILEMODE") 0)(= (getvar "CVPORT") 1));and
(princ "\n  ** You are in Paper Space **")
);if
(if (and (= (getvar "TILEMODE") 0)(> (getvar "CVPORT") 1));and
(princ "\n  ** You are in an Active Viewport **")
);if
(princ)
);defun
Message 8 of 8
scot-65
in reply to: msarqui
Good.
I have this same geometry inside a command reactor.
Still testing it though... Been placed aside for now.
Original post is almost 2 years old now...
Scot-65
”Boost
