Visual LISP, AutoLISP and General Customization
How to sort an an association list?
11 REPLIES 11
Message 1 of 12
aqdam1978
1387 Views, 11 Replies
Does anybody knows how can I sort  an association list?
for example:
(setq lst '((1 . "s") (12 . "t") (-7 . "u") (0 . "v")))
 should be sorted as:
((-7 . "u") (0 . "v") (1 . "s") (12 . "t"))
 { sort on: (car(assoc index lst)) value}
11 REPLIES 11
Message 2 of 12
hmsilva
in reply to: aqdam1978
(vl-sort lst '(lambda (a b) (< (car a) (car b))))
 Henrique
Message 3 of 12
aqdam1978
in reply to: hmsilva
Hi Henrique,
Thank you for your help.
I need it in my lisp code and works fine:
;;*** By Abbas Aqdam ***
;;example: (setq Tabs (GetTabs))
(defun GetTabs ( / Tabs Count i Item Name Order TabsName)
   (setq
      Tabs (vlax-get-property (vlax-get-property (vlax-get-acad-object) 'ActiveDocument) 'Layouts)
      Count (vlax-get-property Tabs 'Count)
      i 0
   );setq
(repeat Count
   (setq
      Item   (vlax-invoke-method Tabs 'Item i)
      Name   (vlax-get-property Item 'Name)
      Order  (vlax-get-property Item 'TabOrder)
      TabsName (append (list (cons Order Name)) TabsName)
      i      (1+ i)
   );setq
);repeat
(vl-sort TabsName '(lambda (a b) (< (car a) (car b))))
);GetTabs
 Thank you so much
Abbas
Message 4 of 12
hmsilva
Hi Abbas,
glad I could help
Henrique
Message 5 of 12
alanjt_
(defun getTabs (/ layouts lst)
  (vlax-for layout (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (setq lst (cons (cons (vla-get-taborder layout) (vla-get-name layout)) lst))
  (vl-sort lst (function (lambda (a b) (< (car a) (car b)))))
Message 6 of 12
aqdam1978
in reply to: alanjt_
Hi Alan,
Thank you for your code.
I have a question:
how can I find out how many or which command are available for a VLA object.
for example
how do you know there is "taborder" function for "layout" VLA-object?
Abbas
Message 7 of 12
BlackBox_
If you know the Object you're interested in, consider vlax-Dump-Object, otherwise, look into Apropos in VLIDE.
"How we think determines what we do, and what we do determines what we get."
Message 8 of 12
BlackBox_
in reply to: BlackBox_
Also...
http://entercad.ru/acadauto.en/
Message 9 of 12
BlackBox_
... Could have sworn we just did this.
Message 10 of 12
alanjt_
We did, and my method for it was totally different. 😛
Message 11 of 12
BlackBox_
Well... This one is pretty sharp; if it were me, I'd mapcar the car out of it. :beer:
Message 12 of 12
alanjt_
For the curious:
(defun getTabs1 (/ layouts lst)
  (mapcar 'cdr (vl-sort lst (function (lambda (a b) (< (car a) (car b))))))
(defun getTabs2 (/ layouts lst lst2)
    (setq lst  (cons (vla-get-name layout) lst)
          lst2 (cons (cons (vla-get-name layout) (vla-get-taborder layout)) lst2)
  (vl-sort lst (function (lambda (a b) (< (cdr (assoc a lst2)) (cdr (assoc b lst2))))))
(defun getTabs3 (/ layouts name lst lst2)
    (setq lst  (cons (setq name (vla-get-name layout)) lst)
          lst2 (cons (cons name (vla-get-taborder layout)) lst2)
(defun getTabs4 (/ layouts)
  (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))))
  (vl-sort
    (cons "Model" (layoutlist))
                (< (vla-get-taborder (vla-item layouts a)) (vla-get-taborder (vla-item layouts b)))
(defun getTabs5 (/ lst)
  (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (setq lst (cons x lst))
  (mapcar 'vla-get-name
          (vl-sort lst (function (lambda (a b) (< (vla-get-taborder a) (vla-get-taborder b)))))
(defun getTabs6 (/ dict def l n)
  (setq dict (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT"))))
  (while (setq def (dictnext dict (null def)))
    (setq l (cons (cdr (assoc 1 (reverse def))) l))
  (cons (car l) (reverse (cdr l)))
Command: (benchmark '((gettabs1) (gettabs2) (getTabs3) (getTabs4) (getTabs5)
(getTabs6)))
Elapsed milliseconds / relative speed for 8192 iteration(s):
    (GETTABS6).....1436 / 2.05 <fastest>
    (GETTABS3).....2372 / 1.24
    (GETTABS1).....2387 / 1.24
    (GETTABS5).....2449 / 1.2
    (GETTABS2).....2745 / 1.07
    (GETTABS4).....2948 / 1 <slowest>
I knew I preferred the non-VL verison for a reason other than just not having to define the layout table.
Now, these all return "Model" which is kind of pointless IMO, but since the OP originally had it in there, I left it. Personally, I'd use gettabs6 and just not add Model to the front of the list.
eg.
(defun _layoutlist (/ dict def l n)
  (reverse (cdr l))
 Returns just like (layoutlist), but in correct tab order.
”Boost
