Visual LISP, AutoLISP and General Customization
How to remove SHX from "hidden" style
4 REPLIES 4
scottbolton
594 Views, 4 Replies
Chaps,
I've received several drawings from a client and, of course, they're full of SHX's that I don't have. Getting a copy is not possible for politcal reasons.
If I delete everything in a drawing and purge the SHX's are still there.
I've located them in a STYLE but the name is "" (from entget: (2 . "")). Any ideas how to get rid of them or to modify the style to a new SHX?
S
4 REPLIES 4
hmsilva
in reply to: scottbolton
(if
  (setq e (tblobjname "style" ""))
   (progn
     (setq ent (entget e))
     (entmod (subst (cons 3 "txt.shx") (assoc 3 ent) ent))
Untested...
HTH
henrique
scottbolton
in reply to: hmsilva
Smiley Embarassed A little embarrassed - I had tried the same code but with DXF 2 to rename the style so that I could manipulate it but it didn't work. Didn't think of changing the SHX in 3.
Ta much.
Ah, but... there are several nameless styles, each with it's own SHX. (tblobjname will only select the first "" it comes to (that's why I'd tried to rename it with DXF 2). How to I get the subsequent styles? (tblnext doesn't return the <entity>.
hmsilva
Hi Scott,
try
(while
  (setq st (tblnext "style" (null st)))
   (if (= (cdr (assoc 2 st)) "")
     (setq st (subst (cons 3 "txt.shx") (assoc 3 st) st))
     (entmod st)
and to rename, maybe something like this (untested)
(setq i 0)
(while (setq tblobj (tblobjname "style" ""))
  (entmod (setq	tblobj (entget tblobj)
		tblobj (subst (cons 2 (strcat "SHX-" (itoa i)) (assoc 2 tblobj) tblobj))
  (setq 1+ i)
HTH
Henrique
owenwengerd
Those "unnamed" styles are shape file references. FWIW, my SuperPurge utility purges those quickly and easily.
Owen Wengerd
ManuSoft
”Boost
