Hi...I'm a total beginner with AutoLISP and I have to get an my first project done. The problem I'm having is that even if I try using the most basic code, taken from this tutorial:
http://www.afralisp.net/dialog-control-language/tutorials/dialog-boxes-and-autolisp-part-1.php
I still get an error as if the dcl file didn't exist. Both the lisp and the DCL files are both set in the same folder, together, no sub-folders or anything like that.
Please take a look and tell me what I'm doing wrong...I'm...really stumped and can't figure it out.
Here's my code:
- DCL:
samp1 : dialog {
label = "Structural Holes";
ok_cancel;
- LISP
(defun C:samp1()
(setq dcl_id (load_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL"))
(if (not (new_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL" dcl_id))
(COMMAND "ZOOM") ;;THIS IS WERE MY FUNCTION GETS STUCK. I ADDED THIS SO I COULD CLEARLY SEE WHAT GOES WRONG
(action_tile
"cancel"
"(done_dialog)(setq userclick nil)"
(action_tile
"accept"
"(done_dialog)(setq userclick T))"
(start_dialog)
(princ)
(princ)
First save the DCL codes to your Autocad Support folder e.g.
C:\Program Files\AutoCAD 20**\Support
and after that load the lisp file to your current opened drawing and run the code .
Good luck .
"\" is treated as an escape character, when feeding a string to a lisp function.
You need to use "\\" in file path strings etc.
Replace
with
(setq dcl_id (load_dialog "C:\\Users\\Eugen Iancu\\Desktop\\learnLisp\\samp1.DCL"))
The first argument of the new_dialog function is the name of a dialog defined in the DCL file, not the DCL file name itself.
Replace
with
(if (not (new_dialog "samp1" dcl_id))
Ian
Whenever I write code that includes a dialog box, I first create a folder,
then add a "test.DWG", and of course place the LSP and DCL files in there
for a total of three files in this folder.
By opening this test.DWG file, you automatically have a "current directory" path
to where you do not need to declare a "Hard-Path" for the DCL file, as the DCL
is located in the current directory.
Whenever you make changes to the LSP file, you have to reload it:
(load "samp1"). Again, the current directory makes it easy to (re)load.
Do yourself a favor and always include (unload_dialog dcl_id) in your LSP file
just after the (start_dialog) so that too can be reloaded (more of a memory
manager than a reload).
Another trick I use is to temporarily cancel out the first and last lines, which saves
me a step to start the program without having to enter the command.
When the program is finished to my satisfaction, the semi-colons are removed.
;(defun c:TEST ()
Good Luck!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Another option is to incorporate the DCL onto your lisp rouitne
(Defun c:showLayerDemo (/ CDiaStr a laylst)
(setq laylst nil)
(defun CDiaStr (/ fnSTR ListBoxDia)
(setq StrDiaFnme (vl-filename-mktemp "tmp.DCL"))
(setq fnSTR (open StrDiaFnme "a"))
(write-line
"dcl_settings : default_dcl_settings { audit_level = 3; }
ShowLayers : dialog
{ label = \"\"; key= \"Taytol\";
: list_box { key = \"StrListS\"; multiple_select =
true; width = 20; height = 20; } spacer ;
ok_cancel;
}" fnSTR)
(close fnSTR)
T
(defun ListBoxDia (DiaName DiaKey Title Lst)
(setq StrDIA (load_dialog StrDiaFnme))
(if (not (new_dialog DiaName StrDIA))
(exit)
(start_list DiaKey)
(mapcar 'add_list Lst)
(end_list)
(set_tile "Taytol" Title)
(action_tile
DiaKey
(vl-prin1-to-string
(quote (set (setq dd (read DiaKey))
(get_tile $key)))))
(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(start_dialog)
(unload_dialog StrDIA)
(while (setq a (tblnext "LAYER" (null a)))
(setq laylst (cons (cdr (assoc 2 a)) laylst)))
(CDiaStr)
(ListBoxDia
"ShowLayers"
"StrListS"
"Select String to Follow"
(acad_strlsort laylst))
(vl-file-delete StrDiaFnme)
(princ)
HTH
Embedding the file.DCL into LISP source automatically...
[code]
t025 (strcat t025 "\noptionh :dialog {\n label = \"Style H Option\";\n:row {\n : boxed_column { \n label = \"Style H Options\";\n : boxed_radio_row {\n key = \"Holes\";\n label = \"How Many Holes Per Side?\";\n : radio_button {key = \"Two\"; ");;
t025 (strcat t025 "label = \"2 Holes Per Side\";}\n : radio_button {key = \"Three\"; label = \"3 Holes Per Side\";}\n }\n : boxed_radio_row {\n key = \"Inline\";\n label = \"Are Holes Inline?\";\n : radio_button {key = \"Y\"; label = \"Yes\";}\n : ");;
t025 (strcat t025 "radio_button {key = \"N\"; label = \"No\";}\n }\n : boxed_radio_row {\n key = \"Chamfer\";\n label = \"Is Inside Hole Chamfered?\";\n : radio_button {key = \"Yes\"; label = \"Yes\";}\n : radio_button {key = \"No\"; label = \"No\";}\n");;
t025 (strcat t025 " }\n : boxed_radio_row {\n key = \"InsOut\";\n label = \"Is Distance from Pole Shaft to Inside or Outside Hole?\";\n : radio_button {key = \"Inside\"; label = \"Inside Hole\";}\n : radio_button {key = \"Outside\"; label = \"Outside Hole\";}\n");;
t025 (strcat t025 " }\n }\n\n : boxed_column { \n label = \"Vang Dimensions and Table Information\";\n : boxed_radio_column {\n key = \"option\";\n label = \"Select Option\" ;\n : radio_button {key = \"1\"; label = \"Double Sided - Flats 1 && 7\" ");;
t025 (strcat t025 ";}\n : radio_button {key = \"2\"; label = \"Double Sided - Flats 4 && 10\" ;}\n : radio_button {key = \"3\"; label = \"Double Sided - Positive Angle\" ;}\n : radio_button {key = \"4\"; label = \"Double Sided - Negative Angle\";}\n");;
t025 (strcat t025 " : radio_button {key = \"5\"; label = \"Single Sided - Flat 1\" ;}\n : radio_button {key = \"6\"; label = \"Single Sided - Flat 4\" ;}\n : radio_button {key = \"7\"; label = \"Single Sided - Flat 7\" ;}\n : radio_button ");;
t025 (strcat t025 "{key = \"8\"; label = \"Single Sided - Flat 10\" ;}\n : radio_button {key = \"9\"; label = \"Single Sided - Positive Angle - Opposite Side\" ;}\n : radio_button {key = \"10\"; label = \"Single Sided - Positive Angle - Near Side\" ");;
t025 (strcat t025 ";}\n : radio_button {key = \"11\"; label = \"Single Sided - Negative Angle - Opposite Side\" ;}\n : radio_button {key = \"12\"; label = \"Single Sided - Negative Angle - Near Side\" ;}\n }\n }\n\n \n : boxed_column { \n key = ");;
t025 (strcat t025 "\"dimensions\";\n label = \"Dimensions of Vang\";\n : edit_box {\n label = \"Width of Vang (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"width\";\n }\n : edit_box ");;
t025 (strcat t025 "{\n label = \"Hole to Shaft Dimension (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"hole2shaft\";\n }\n : edit_box {\n label = \"Weld Size:\";\n edit_limit = ");;
t025 (strcat t025 "4;\n edit_width = 4;\n fixed_height = true;\n is_enabled = true;\n key = \"weldsz\";\n }\n : edit_box {\n label = \"Hole Diameter (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = ");;
t025 (strcat t025 "true;\n key = \"holedia\";\n }\n : edit_box {\n label = \"Radius (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"rad\";\n }\n : edit_box {\n label = \"Vertical Hole Spacing (Include Inch Mark):\";\n");;
t025 (strcat t025 " edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"VERT_HSPACING\";\n }\n : edit_box {\n label = \"Horizontal Hole Spacing (Include Inch mark):\";\n edit_limit ");;
t025 (strcat t025 "= 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"HORZ_HSPACING\";\n }\n }\n\n : boxed_radio_column { \n key = \"table\";\n label = \"Number of Lines in Table\" ;\n : radio_button {key = \"N1\"; ");;
t025 (strcat t025 "label = \"1 Line in Table\" ;}\n : radio_button {key = \"N2\"; label = \"2 Lines in Table\" ;}\n : radio_button {key = \"N3\"; label = \"3 Lines in Table\" ;}\n : radio_button {key = \"N4\"; label = \"4 Lines in Table\" ;}\n : radio_button ");;
t025 (strcat t025 "{key = \"N5\"; label = \"5 Lines in Table\" ;}\n }\n }\n\n}\n\n:row {alignment=centered; fixed_width=true;\n ok_cancel;\n}\n}\n\n"))
;(str_princ (list ))
[/code]
HERE is Original DCL
[code]
optionh :dialog {
label = "Style H Option";
:row {
: boxed_column { //COLUMN 1
label = "Style H Options";
: boxed_radio_row {
key = "Holes";
label = "How Many Holes Per Side?";
: radio_button {key = "Two"; label = "2 Holes Per Side";}
: radio_button {key = "Three"; label = "3 Holes Per Side";}
: boxed_radio_row {
key = "Inline";
label = "Are Holes Inline?";
: radio_button {key = "Y"; label = "Yes";}
: radio_button {key = "N"; label = "No";}
: boxed_radio_row {
key = "Chamfer";
label = "Is Inside Hole Chamfered?";
: radio_button {key = "Yes"; label = "Yes";}
: radio_button {key = "No"; label = "No";}
: boxed_radio_row {
key = "InsOut";
label = "Is Distance from Pole Shaft to Inside or Outside Hole?";
: radio_button {key = "Inside"; label = "Inside Hole";}
: radio_button {key = "Outside"; label = "Outside Hole";}
}//COLUMN 1
: boxed_column { //COLUMN 2
label = "Vang Dimensions and Table Information";
key = "option";
label = "Select Option" ;
: radio_button {key = "1"; label = "Double Sided - Flats 1 && 7" ;}
: radio_button {key = "2"; label = "Double Sided - Flats 4 && 10" ;}
: radio_button {key = "3"; label = "Double Sided - Positive Angle" ;}
: radio_button {key = "4"; label = "Double Sided - Negative Angle";}
: radio_button {key = "5"; label = "Single Sided - Flat 1" ;}
: radio_button {key = "6"; label = "Single Sided - Flat 4" ;}
: radio_button {key = "7"; label = "Single Sided - Flat 7" ;}
: radio_button {key = "8"; label = "Single Sided - Flat 10" ;}
: radio_button {key = "9"; label = "Single Sided - Positive Angle - Opposite Side" ;}
: radio_button {key = "10"; label = "Single Sided - Positive Angle - Near Side" ;}
: radio_button {key = "11"; label = "Single Sided - Negative Angle - Opposite Side" ;}
: radio_button {key = "12"; label = "Single Sided - Negative Angle - Near Side" ;}
}//COLUMN 2
: boxed_column { //COLUMN 3
key = "dimensions";
label = "Dimensions of Vang";
: edit_box {
label = "Width of Vang (Include Inch Mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "width";
: edit_box {
label = "Hole to Shaft Dimension (Include Inch Mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "hole2shaft";
: edit_box {
label = "Weld Size:";
edit_limit = 4;
edit_width = 4;
is_enabled = true;
key = "weldsz";
: edit_box {
label = "Hole Diameter (Include Inch Mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "holedia";
: edit_box {
label = "Radius (Include Inch Mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "rad";
: edit_box {
label = "Vertical Hole Spacing (Include Inch Mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "VERT_HSPACING";
: edit_box {
label = "Horizontal Hole Spacing (Include Inch mark):";
edit_limit = 10;
edit_width = 10;
is_enabled = true;
key = "HORZ_HSPACING";
}//COLUMN 3
: boxed_radio_column { //COLUMN 4
key = "table";
label = "Number of Lines in Table" ;
: radio_button {key = "N1"; label = "1 Line in Table" ;}
: radio_button {key = "N2"; label = "2 Lines in Table" ;}
: radio_button {key = "N3"; label = "3 Lines in Table" ;}
: radio_button {key = "N4"; label = "4 Lines in Table" ;}
: radio_button {key = "N5"; label = "5 Lines in Table" ;}
}//COLUMN 4
}//ROW
ok_cancel;
}//DIALOG
[/code]
