Visual LISP, AutoLISP and General Customization
How to properly link to DCL?
5 REPLIES 5
eug3n91
1184 Views, 5 Replies
Hi...I'm a total beginner with AutoLISP and I have to get an my first project done. The problem I'm having is that even if I try using the most basic code, taken from this tutorial:
http://www.afralisp.net/dialog-control-language/tutorials/dialog-boxes-and-autolisp-part-1.php
I still get an error as if the dcl file didn't exist. Both the lisp and the DCL files are both set in the same folder, together, no sub-folders or anything like that.
Please take a look and tell me what I'm doing wrong...I'm...really stumped and can't figure it out.
Here's my code:
- DCL:
samp1 : dialog {
    label = "Structural Holes";
    ok_cancel;
- LISP
(defun C:samp1()
  (setq dcl_id (load_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL"))
  (if (not (new_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL" dcl_id))
    (COMMAND "ZOOM") ;;THIS IS WERE MY FUNCTION GETS STUCK. I ADDED THIS SO I COULD CLEARLY SEE           WHAT GOES WRONG
  (action_tile
       "cancel"
       "(done_dialog)(setq userclick nil)"
  (action_tile
    "accept"
    "(done_dialog)(setq userclick T))"
  (start_dialog)
  (princ)
(princ)
5 REPLIES 5
_Tharwat
in reply to: eug3n91
First save the DCL codes to your Autocad Support folder e.g.
C:\Program Files\AutoCAD 20**\Support
and after that load the lisp file to your current opened drawing and run the code .
Good luck .
Ian_Bryant
"\" is treated as an escape character, when feeding a string to a lisp function.
You need to use "\\" in file path strings etc.
Replace
with
(setq dcl_id (load_dialog "C:\\Users\\Eugen Iancu\\Desktop\\learnLisp\\samp1.DCL"))
The first argument of the new_dialog function is the name of a dialog defined in the DCL file, not the DCL file name itself.
Replace
with
(if (not (new_dialog "samp1" dcl_id))
Ian
scot-65
Whenever I write code that includes a dialog box, I first create a folder,
then add a "test.DWG", and of course place the LSP and DCL files in there
for a total of three files in this folder.
By opening this test.DWG file, you automatically have a "current directory" path
to where you do not need to declare a "Hard-Path" for the DCL file, as the DCL
is located in the current directory.
Whenever you make changes to the LSP file, you have to reload it:
(load "samp1"). Again, the current directory makes it easy to (re)load.
Do yourself a favor and always include (unload_dialog dcl_id) in your LSP file
just after the (start_dialog) so that too can be reloaded (more of a memory
manager than a reload).
Another trick I use is to temporarily cancel out the first and last lines, which saves
me a step to start the program without having to enter the command.
When the program is finished to my satisfaction, the semi-colons are removed.
;(defun c:TEST ()
Good Luck!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
pbejse
Another option is to incorporate the DCL onto your lisp rouitne
(Defun c:showLayerDemo  (/ CDiaStr a laylst)
(setq laylst nil)
(defun CDiaStr  (/ fnSTR ListBoxDia)
            (setq StrDiaFnme (vl-filename-mktemp "tmp.DCL"))
            (setq fnSTR (open StrDiaFnme "a"))
            (write-line
                  "dcl_settings : default_dcl_settings { audit_level = 3; }
  ShowLayers : dialog
  { label = \"\"; key= \"Taytol\";
  : list_box { key = \"StrListS\"; multiple_select =
  true; width = 20; height = 20; } spacer ;
  ok_cancel;
  }"              fnSTR)
            (close fnSTR)
            T
(defun ListBoxDia (DiaName DiaKey Title Lst)
     (setq StrDIA (load_dialog StrDiaFnme))
    (if (not (new_dialog DiaName StrDIA))
          (exit)
    (start_list DiaKey)
    (mapcar 'add_list Lst)
    (end_list)
    (set_tile "Taytol" Title)
    (action_tile
          DiaKey
          (vl-prin1-to-string
                (quote (set (setq dd (read DiaKey))
                            (get_tile $key)))))
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "cancel" "(done_dialog 0)")
    (start_dialog)
    (unload_dialog StrDIA)
 (while (setq a (tblnext "LAYER" (null a)))
             (setq laylst (cons (cdr (assoc 2 a)) laylst)))
       (CDiaStr)
       (ListBoxDia
             "ShowLayers"
             "StrListS"
             "Select String to Follow"
             (acad_strlsort laylst))
       (vl-file-delete StrDiaFnme)
(princ)
HTH
diagodose2009
in reply to: pbejse
Embedding  the file.DCL into LISP source automatically...
[code]
t025 (strcat t025  "\noptionh :dialog {\n label = \"Style H Option\";\n:row {\n : boxed_column { \n label = \"Style H Options\";\n : boxed_radio_row {\n key = \"Holes\";\n label = \"How Many Holes Per Side?\";\n : radio_button {key = \"Two\"; ");;
t025 (strcat t025  "label = \"2 Holes Per Side\";}\n : radio_button {key = \"Three\"; label = \"3 Holes Per Side\";}\n }\n : boxed_radio_row {\n key = \"Inline\";\n label = \"Are Holes Inline?\";\n : radio_button {key = \"Y\"; label = \"Yes\";}\n : ");;
t025 (strcat t025  "radio_button {key = \"N\"; label = \"No\";}\n }\n : boxed_radio_row {\n key = \"Chamfer\";\n label = \"Is Inside Hole Chamfered?\";\n : radio_button {key = \"Yes\"; label = \"Yes\";}\n : radio_button {key = \"No\"; label = \"No\";}\n");;
t025 (strcat t025  " }\n : boxed_radio_row {\n key = \"InsOut\";\n label = \"Is Distance from Pole Shaft to Inside or Outside Hole?\";\n : radio_button {key = \"Inside\"; label = \"Inside Hole\";}\n : radio_button {key = \"Outside\"; label = \"Outside Hole\";}\n");;
t025 (strcat t025  " }\n }\n\n : boxed_column { \n label = \"Vang Dimensions and Table Information\";\n : boxed_radio_column {\n key = \"option\";\n label = \"Select Option\" ;\n : radio_button {key = \"1\"; label = \"Double Sided - Flats 1 && 7\" ");;
t025 (strcat t025  ";}\n : radio_button {key = \"2\"; label = \"Double Sided - Flats 4 && 10\" ;}\n : radio_button {key = \"3\"; label = \"Double Sided - Positive Angle\" ;}\n : radio_button {key = \"4\"; label = \"Double Sided - Negative Angle\";}\n");;
t025 (strcat t025  " : radio_button {key = \"5\"; label = \"Single Sided - Flat 1\" ;}\n : radio_button {key = \"6\"; label = \"Single Sided - Flat 4\" ;}\n : radio_button {key = \"7\"; label = \"Single Sided - Flat 7\" ;}\n : radio_button ");;
t025 (strcat t025  "{key = \"8\"; label = \"Single Sided - Flat 10\" ;}\n : radio_button {key = \"9\"; label = \"Single Sided - Positive Angle - Opposite Side\" ;}\n : radio_button {key = \"10\"; label = \"Single Sided - Positive Angle - Near Side\" ");;
t025 (strcat t025  ";}\n : radio_button {key = \"11\"; label = \"Single Sided - Negative Angle - Opposite Side\" ;}\n : radio_button {key = \"12\"; label = \"Single Sided - Negative Angle - Near Side\" ;}\n }\n }\n\n \n : boxed_column { \n key = ");;
t025 (strcat t025  "\"dimensions\";\n label = \"Dimensions of Vang\";\n : edit_box {\n label = \"Width of Vang (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"width\";\n }\n : edit_box ");;
t025 (strcat t025  "{\n label = \"Hole to Shaft Dimension (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"hole2shaft\";\n }\n : edit_box {\n label = \"Weld Size:\";\n edit_limit = ");;
t025 (strcat t025  "4;\n edit_width = 4;\n fixed_height = true;\n is_enabled = true;\n key = \"weldsz\";\n }\n : edit_box {\n label = \"Hole Diameter (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = ");;
t025 (strcat t025  "true;\n key = \"holedia\";\n }\n : edit_box {\n label = \"Radius (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"rad\";\n }\n : edit_box {\n label = \"Vertical Hole Spacing (Include Inch Mark):\";\n");;
t025 (strcat t025  " edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"VERT_HSPACING\";\n }\n : edit_box {\n label = \"Horizontal Hole Spacing (Include Inch mark):\";\n edit_limit ");;
t025 (strcat t025  "= 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"HORZ_HSPACING\";\n }\n }\n\n : boxed_radio_column { \n key = \"table\";\n label = \"Number of Lines in Table\" ;\n : radio_button {key = \"N1\"; ");;
t025 (strcat t025  "label = \"1 Line in Table\" ;}\n : radio_button {key = \"N2\"; label = \"2 Lines in Table\" ;}\n : radio_button {key = \"N3\"; label = \"3 Lines in Table\" ;}\n : radio_button {key = \"N4\"; label = \"4 Lines in Table\" ;}\n : radio_button ");;
t025 (strcat t025  "{key = \"N5\"; label = \"5 Lines in Table\" ;}\n }\n }\n\n}\n\n:row {alignment=centered; fixed_width=true;\n ok_cancel;\n}\n}\n\n"))
;(str_princ (list ))
[/code]
HERE is Original DCL Man Tongue Smiley WinkSmiley Embarassed
[code]
optionh :dialog {
   label = "Style H Option";
:row {
  : boxed_column {         //COLUMN 1
  label = "Style H Options";
  : boxed_radio_row {
    key = "Holes";
    label = "How Many Holes Per Side?";
    : radio_button {key = "Two"; label = "2 Holes Per Side";}
    : radio_button {key = "Three"; label = "3 Holes Per Side";}
  : boxed_radio_row {
    key = "Inline";
    label = "Are Holes Inline?";
    : radio_button {key = "Y"; label = "Yes";}
    : radio_button {key = "N"; label = "No";}
  : boxed_radio_row {
    key = "Chamfer";
    label = "Is Inside Hole Chamfered?";
    : radio_button {key = "Yes"; label = "Yes";}
    : radio_button {key = "No"; label = "No";}
  : boxed_radio_row {
    key = "InsOut";
    label = "Is Distance from Pole Shaft to Inside or Outside Hole?";
    : radio_button {key = "Inside"; label = "Inside Hole";}
    : radio_button {key = "Outside"; label = "Outside Hole";}
 }//COLUMN 1
  : boxed_column {          //COLUMN 2
  label = "Vang Dimensions and Table Information";
    key = "option";
    label = "Select Option" ;
    : radio_button {key = "1"; label = "Double Sided - Flats 1 && 7" ;}
    : radio_button {key = "2"; label = "Double Sided - Flats 4 && 10" ;}
    : radio_button {key = "3"; label = "Double Sided - Positive Angle" ;}
    : radio_button {key = "4"; label = "Double Sided - Negative Angle";}
    : radio_button {key = "5"; label = "Single Sided - Flat 1" ;}
    : radio_button {key = "6"; label = "Single Sided - Flat 4" ;}
    : radio_button {key = "7"; label = "Single Sided - Flat 7" ;}
    : radio_button {key = "8"; label = "Single Sided - Flat 10" ;}
    : radio_button {key = "9"; label = "Single Sided - Positive Angle - Opposite Side" ;}
    : radio_button {key = "10"; label = "Single Sided - Positive Angle - Near Side" ;}
    : radio_button {key = "11"; label = "Single Sided - Negative Angle - Opposite Side" ;}
    : radio_button {key = "12"; label = "Single Sided - Negative Angle - Near Side" ;}
 }//COLUMN 2
  : boxed_column {                   //COLUMN 3
    key = "dimensions";
    label = "Dimensions of Vang";
    : edit_box {
      label = "Width of Vang (Include Inch Mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "width";
    : edit_box {
      label = "Hole to Shaft Dimension (Include Inch Mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "hole2shaft";
    : edit_box {
      label = "Weld Size:";
      edit_limit = 4;
      edit_width = 4;
      is_enabled = true;
      key = "weldsz";
    : edit_box {
      label = "Hole Diameter (Include Inch Mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "holedia";
    : edit_box {
      label = "Radius (Include Inch Mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "rad";
    : edit_box {
      label = "Vertical Hole Spacing (Include Inch Mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "VERT_HSPACING";
    : edit_box {
      label = "Horizontal Hole Spacing (Include Inch mark):";
      edit_limit = 10;
      edit_width = 10;
      is_enabled = true;
      key = "HORZ_HSPACING";
     }//COLUMN 3
   : boxed_radio_column {                   //COLUMN 4
     key = "table";
     label = "Number of Lines in Table" ;
     : radio_button {key = "N1"; label = "1 Line in Table" ;}
     : radio_button {key = "N2"; label = "2 Lines in Table" ;}
     : radio_button {key = "N3"; label = "3 Lines in Table" ;}
     : radio_button {key = "N4"; label = "4 Lines in Table" ;}
     : radio_button {key = "N5"; label = "5 Lines in Table" ;}
   }//COLUMN 4
}//ROW
     ok_cancel;
}//DIALOG
[/code]
”Boost
