Hey everyone , i'm using an attribute rotation function to rotate attributes if a block is rotated. they would be rotated orthogonally only, and i think this picture will explain best.
Here is the rotation function.
(defun ssvla (selection-set / index vla-list) (setq index (if selection-set (1- (sslength selection-set)) -1 ) ) (while (>= index 0) (setq vla-list (cons (vlax-ename->vla-object (ssname selection-set index) ) vla-list ) index (1- index) ) ) vla-list );; ssvla (defun HORIZ (/ ss) (if (setq ss (ssget "_L" '((0 . "INSERT")))) (foreach obj (ssvla ss) (foreach att (vlax-safearray->list (vlax-variant-value (vla-getattributes obj)) ) (vla-put-rotation att 0.0) ) ) ) (princ)
and where it is being called, for completeness.
(defun MySub (a1 a2 a3 insertpt1 / OBJ P2 P3 doc) ;subfunction (vl-load-com) ;load vlisp functions ;(setq doc (vla-get-activedocument (vlax-get-acad-object))) (if (= objx 1) ;if objx is 1, ent=line or pline (progn ;preform these actions (setvar "osmode" 0) ;first turn off osnap (princ) (if (> a2 0.0) ;if trim dist is greater than 0.0 preform (progn ;these actions (setq obj (vlax-ename->vla-object name)) ;get entity object (if (eq (vla-get-ObjectName obj) "AcDbPolyline") ;if it is a LwPolyline (setq p3 insertpt1 ;get first break point p2 (angle insertpt1 (vlax-curve-getpointatparam obj (fix (vlax-curve-getparamatpoint obj (vlax-curve-getClosestPointTo obj insertpt1 T)))))) (setq p3 insertpt1 ;and second break point p2 (angle (vlax-curve-getStartpoint obj) (vlax-curve-getEndPoint obj))) ) ;if (command "break" name (polar p3 p2 a2) (polar p3 p2 a3)) (command "_insert" a1 insertpt1 "" "" pause) ;insert into space ;(vla-sendcommand doc (strcat "horiz" " " "L" " " " ")) ;break line (HORIZ) ) ;progn (princ "\n......Selected....\n......Breaking Lines....") ;status ) ;if ) (progn (command "_insert" a1 insertpt1 "" "" pause) ;insert onto line ;(vla-sendcommand doc (strcat "horiz" " " "L" " " " ")) (HORIZ) (princ) ) ) ;if (princ "\n......Insertion Completed!") ;princ (princ) ;(ARXUNLOAD "AT_CUSTDB" "DBX") ;print clear (setq name nil) ) ;MySub
Would I need to establish a check to see if the rotation is a 90 or 270 and then if so have each attribute moved by a value of the text height? first att moved up second att moved down? How would I go about this, properly, and with the ability to incorporate into the existing code?
Any help, as always, is greatly appreciated.
Solved by bhull1985. Go to Solution.
Was my thinking-out-loud method correct?
Or does just nobody know how to do this? 😕
Can anyone let me know if the move method is the best way to accomplish this or if there is a vla command that would seperate stacked attributes?
Thank you, still having this problem 😕
Answer provided by the amazing mr henrique
(defun MyHor (/ data ent flag h l p1 pts r typ) (setq data (entget (setq ent (entlast))) r (cdr (assoc 50 data)) ) (if (or (equal r (/ pi 2.0) 1e-8) (equal r (* pi 1.5) 1e-8) ) (setq flag T) ) (cond ((and (eq 1 (cdr (assoc 66 data))) (not flag)) (while (/= "SEQEND" (setq typ (cdr (assoc 0 data)))) (cond ((eq "ATTRIB" typ) (entmod (subst (cons 50 0.0) (assoc 50 data) data)) ) ) (setq data (entget (setq ent (entnext ent)))) ) (entupd (entlast)) ) ((and (eq 1 (cdr (assoc 66 data))) flag) (while (/= "SEQEND" (setq typ (cdr (assoc 0 data)))) (cond ((eq "ATTRIB" typ) (setq pts (setq l (cons (cdr (assoc 11 data)) pts)) h (cdr (assoc 40 data)) ) ) ) (setq data (entget (setq ent (entnext ent)))) ) (setq p1 (midpt pts) p1 (mapcar '+ p1 (list 0.0 (* 1.25 h) 0.0)) ) (setq data (entget (setq ent (entlast)))) (while (/= "SEQEND" (setq typ (cdr (assoc 0 data)))) (cond ((eq "ATTRIB" typ) (entmod (setq data (subst (cons 11 p1) (assoc 11 data) data))) (entmod (subst (cons 50 0.0) (assoc 50 data) data)) (setq p1 (mapcar '- p1 (list 0.0 (* 1.25 h) 0.0))) ) ) (setq data (entget (setq ent (entnext ent)))) ) ) (entupd (entlast)) ) (princ) ) (defun midpt (ptlst / a b) (mapcar '(lambda (a b) (/ (+ a b) 2)) (apply 'mapcar (cons 'min ptlst)) (apply 'mapcar (cons 'max ptlst)) ) )
Close enough, shows a way to do it and this thread wants closing. Done!
