hello
i want to put the information of summaryinfo into the property of the file visible in the file explorer of windows XP
(setq activedocument (vla-get-activedocument (vlax-get-acad-object)))
i want to put this in the properties of the file (vla-get-title SummaryInfo)
because if i set the summaryInfo in autocad, when i open the explorer this information is not here
thank you (merci beaucoup 🙂
lolbru
try something like
(setq SummaryInfo (vla-get-SummaryInfo (vla-get-activedocument (vlax-get-acad-object))))
(vla-put-Author SummaryInfo "Test")
(vla-put-Comments SummaryInfo "Test 1")
(vla-put-HyperlinkBase SummaryInfo "Test 2")
(vla-put-Keywords SummaryInfo "Test 3")
(vla-put-RevisionNumber SummaryInfo "Test 4")
(vla-put-Subject SummaryInfo "Test 5")
(vla-put-Title SummaryInfo "Test 6")
Henrique
"j'ai deja fait cela, le problème n'est pas de remplir les champs summaryInfo
mais qu'il soit visible dans l'explorateur de windows"
google trad
I've already done that, the problem is not spotted summaryInfo
but it is visible in windows explorer
my original code
(setq SummaryInfo (vla-get-SummaryInfo activedocument))
(vla-put-title
SummaryInfo
(strcat chemin (getvar "dwgname"))
(vla-put-comments
SummaryInfo
"Ne pas modifier ces informations !!"
it's work, but when i open the windows explorer ther are not informations in field title
it's appears when i right click on files go to properties and read only summary tab
and they are another summary tab in read write but no information into 😞
