@CHADK76 wrote:
I could not find where to make the attribute increment in the block editor.
The incrementing is not in the Block definition, but in the answer to the Attribute value prompt, supplied by the code when the Block is inserted.
If my guess before [that you have a constant-value Attribute] is correct, you could make a new one to replace it, and ensure that it is not constant:
Or, I think you can "fix" one that's defined to be constant by opening the Block in BEDIT, picking on the Attribute Definition, and in Properties, emptying out any content from the Value slot:
Another possibility for a reason that they all say "1" is that you didn't use an Attribute, but simply used a piece of Text or Mtext with content of "1" in the Block. If so, replace that with an Attribute Definition.
It is an attribute definition as shown in attachment. Do I need to add anything in the lisp file?
But it has "1" in the "Value" slot [fuzzy from the low resolution of your image]:
That's the constant value -- take that out.
HOWEVER, in quickie trial, I'm finding that if I do only that, when I then Insert one, it doesn't prompt for a value; there may be some other Property that you need to change, or you may need to replace it with a new one -- I'll leave it to you to experiment.
I cleared the value for my attribute definition VERTEX in my block. I also set the attdia variable to 0 in my drawing. I am now getting the lisp to work, but it is starting with zero for my first vertice. I tried putting 1 in the value as a test and it still starts with zero. Do I need to add something else in the block to make it start with 1 instead of zero?
Chad
