How to get the nearest distance from a point to another?
7 REPLIES 7
Message 1 of 8
maikhanhmst
525 Views, 7 Replies
Hi everyone,
Could someone help me how to get the nearest distance from a point to a point?
I could use
(- (car pt1) (car pt2))
 to get the distance. Is there another way to do it?
My code
(defun c:test()
(setq pt1 (getpoint "\nPoint 1"))
(setq pt2 (getpoint "\nPoint 2"))
(setq dist (- (car pt2) (car pt1)))
); defun
 Thanks.
7 REPLIES 7
Message 2 of 8
_Tharwat
in reply to: maikhanhmst
There must be one point to get the other one which is the nearest , explain in more details with an example would help a lot .
Message 3 of 8
Shneuph
Does  (setq dist (distance pt1 pt2)) work?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 4 of 8
Kent1Cooper
@maikhanhmst wrote:
Hi everyone,
I could use
That will get the difference between the X coordinates of the points, which will be the distance between them only when they share the same YZ coordinates.  The (distance) function suggested by Shneuph is what you want.  Unlike the above, which will sometimes return a negative value, (distance) always returns a positive [absolute] value.  And it accounts for the 3rd dimension if both are 3D points with different Z coordinates.
Kent Cooper, AIA
Message 5 of 8
maikhanhmst
in reply to: Kent1Cooper
Sorry, for late respond and not clear from the question.
You get what I mean. The distance I want to get is different between the X coordiantes (car) or Y coordinates (cadr).
Thank you.
Message 6 of 8
stevor
Something like
 (mapcar '- P1 P2 )
OR
 (mapcar '(lambda ( a b) (- a b)) P1 P2)
S
Message 7 of 8
Shneuph
Your original code gets the difference between the x coordinates of the 2 points.  I don't know of an easier way.
You can check for negative values (as Kent said you will possibly get) and make it positive with an if statement.  I don't think LISP has an absolute value function.
(if (< (- (car pt1) (car pt2)) 0)
(* -1 (- (car pt1) (car pt2)))
);if
Message 8 of 8
Kent1Cooper
in reply to: Shneuph
@Shneuph wrote:
....  I don't think LISP has an absolute value function. ...
Yes, it does, called, logically enough, (abs).  If you want the difference in location between two points as a list of absolute-value differences in X and Y [and Z, for that matter], as a pure XYZ distance without direction:
(mapcar 'abs (mapcar '- p1 p2))
Kent Cooper, AIA
”Boost
