I am working on a lisp routine and want to make an IF statement based on whether the user is in paper space or model space.
How do I determine the current space?
This seems like a basic request and I assume this information is stored in a system variable but a 10 minute search has come up empty.
(if(and(zerop(getvar"tilemode"))(= 1 (getvar"cvport")))(princ"\nPspace")(princ"\nMspace"))
Thanks guys.
I never have much time to work on lisp so I ended up making two routines for now, one for PS and one for MS.
I will take a cloder look at your suggestions when I have more time. I did test Paul's code at the command line and it was able to acuratley determine what space was current. I will probably look at this option first.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Only the CVPORT system variable need be tested:
(if (= 1 (getvar 'cvport)) < user is in paperspace > < user is in modelspace > )
Nice one Lee_Mac
@Lee_Mac wrote:Only the CVPORT system variable need be tested:
Depending on program intent it can be handy to know if you are in floating modelspace. Determining that requires more than testing only CVPORT.
Correct - TILEMODE must also be tested if it is necessary to differentiate between the Model layout & viewing Modelspace through a Paperspace Viewport, but I believe my above suggestion is the most succinct way to determine the current space, as the OP requested.
@Lee_Mac wrote:Correct - TILEMODE must also be tested if it is necessary to differentiate between the Model layout & viewing Modelspace through a Paperspace Viewport.
I suppose it doesn't have to be TILEMODE. One could also use CTAB, since you can't rename the model layout. Same difference in the end.
