How to get current space?
10 REPLIES 10
Message 1 of 11
JeffPaulsen
1026 Views, 10 Replies
I am working on a lisp routine and want to make an IF statement based on whether the user is in paper space or model space.
How do I determine the current space?
This seems like a basic request and I assume this information is stored in a system variable but a 10 minute search has come up empty.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
10 REPLIES 10
Message 2 of 11
in reply to: JeffPaulsen
You might try this routine.  It is the one I use.
Message 3 of 11
paullimapa
(if(and(zerop(getvar"tilemode"))(= 1 (getvar"cvport")))(princ"\nPspace")(princ"\nMspace"))
Paul Li
IT Specialist
@The Office
Message 4 of 11
JeffPaulsen
in reply to: paullimapa
Thanks guys.
I never have much time to work on lisp so I ended up making two routines for now, one for PS and one for MS.
I will take a cloder look at your suggestions when I have more time. I did test Paul's code at the command line and it was able to acuratley determine what space was current. I will probably look at this option first.
Jeff Paulsen
Message 5 of 11
scot-65
Yes, both TILEMODE and CVPORT must be investigated
to determine what space is current.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 6 of 11
Lee_Mac
Only the CVPORT system variable need be tested:
(if (= 1 (getvar 'cvport))
    < user is in paperspace >
    < user is in modelspace >
Message 7 of 11
paullimapa
in reply to: Lee_Mac
Nice one Lee_Mac
AOL @ Exchange App Store         DDSetup @ Exchange App Store
Paul Li
IT Specialist
@The Office
Message 8 of 11
Lee_Mac
Message 9 of 11
Jason.Piercey
Depending on program intent it can be handy to know if you are in floating modelspace.  Determining that requires more than testing only CVPORT.
Message 10 of 11
Lee_Mac
in reply to: Jason.Piercey
Correct - TILEMODE must also be tested if it is necessary to differentiate between the Model layout & viewing Modelspace through a Paperspace Viewport, but I believe my above suggestion is the most succinct way to determine the current space, as the OP requested.
Message 11 of 11
Jason.Piercey
@Lee_Mac wrote:
Correct - TILEMODE must also be tested if it is necessary to differentiate between the Model layout & viewing Modelspace through a Paperspace Viewport.
I suppose it doesn't have to be TILEMODE.  One could also use CTAB, since you can't rename the model layout.  Same difference in the end.
”Boost
