Hi.
I have some multiline attributes that contain strings that are longer than 250 characters. Someone that know how to empty the attribute using autolisp?
Thanks in advance.
\Freddy
@FK wrote:Hi.
Thanks in advance.
\Freddy
Are there other attributes on the block besides the multiline? or blank all attributes regardless if its multiline or not?
@pbejse wrote:Are there other attributes on the block besides the multiline? or blank all attributes regardless if its multiline or not?
(defun c:begone (/ atr)(vl-load-com) (while (setq atr (car (nentsel "\nSelect Attribute:" ))) (vla-put-textstring (vlax-ename->vla-object atr) ""))) (defun c:begonem (/ atr)(vl-load-com) (while (setq atr (car (nentsel "\nSelect Attribute:" ))) (if (eq (vla-get-MTextAttribute (setq atr (vlax-ename->vla-object atr))) :vlax-true) (vla-put-textstring atr ""))) ) (defun c:begoneML (/ ss)(vl-load-com) (if (setq ss (ssget ":L" '((0 . "INSERT")(66 . 1)))) (repeat (sslength ss) (foreach itm (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes) (if (eq (vla-get-MTextAttribute itm) :vlax-true) (vla-put-textstring itm ""))) (ssdel (ssname ss 0) ss) ))) (defun c:begoner ( / ss)(vl-load-com) (if (setq ss (ssget ":L" '((0 . "INSERT")(66 . 1)))) (repeat (sslength ss) (foreach itm (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes) (vla-put-textstring itm "")) (ssdel (ssname ss 0) ss) )) )
GTG
Please try attached routine, select blocks, specify which attribute, then in the dialogue box set "Replace mode" as "New" and "New text" as a space.
