Visual LISP, AutoLISP and General Customization
How to empty a multiline attribute?
4 REPLIES 4
fk
306 Views, 4 Replies
Hi.
I have some multiline attributes that contain strings that are longer than 250 characters. Someone that know how to empty the attribute using autolisp?
Thanks in advance.
\Freddy
4 REPLIES 4
pbejse
in reply to: fk
@FK wrote:
Hi.
Thanks in advance.
\Freddy
Are there other attributes on the block besides the multiline?  or blank all attributes regardless if its multiline or not?
pbejse
in reply to: pbejse
(defun c:begone (/ atr)(vl-load-com)
  (while (setq atr (car (nentsel "\nSelect Attribute:" )))
    		(vla-put-textstring (vlax-ename->vla-object atr) "")))
(defun c:begonem (/ atr)(vl-load-com)
    		(if (eq (vla-get-MTextAttribute (setq atr (vlax-ename->vla-object atr))) :vlax-true)
    		(vla-put-textstring atr "")))
(defun c:begoneML (/ ss)(vl-load-com)
  	(if (setq ss (ssget ":L" '((0 . "INSERT")(66 . 1))))
	  	(repeat (sslength ss)
		  (foreach itm (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes)
		    	(if (eq (vla-get-MTextAttribute itm) :vlax-true)
			  	(vla-put-textstring itm "")))
		  (ssdel (ssname ss 0) ss)
(defun c:begoner ( / ss)(vl-load-com)
GTG
3wood
in reply to: fk
Please try attached routine, select blocks, specify which attribute, then in the dialogue box set "Replace mode" as "New" and "New text" as a space.
fk
in reply to: pbejse
This is great! Thanks  a lot "pbejse". You saved my day.
\Freddy
”Boost
