Hi Paul,
I thought for sure I would see (initget 1) worked in there. :-))
-Jason
"Paul Turvill" wrote in message
news:C82781BEE2AFE07B80B991E7F8C75752@in.WebX.maYIadrTaRb...
> (defun C:drawPline (/ cmde p)
> (setq cmde (getvar "cmdecho")
> p (getpoint "\nPlease Select Starting Point: "))
> (setvar "cmdecho" 0)
> (command "_.pline" P)
> (setvar "cmdecho" 1)
> (while (= (logand (getvar "cmdactive") 1) 1)
> (command pause))
> (setvar "cmdecho" cmde)
> (princ)
> ___
> "rchiu2001" wrote in message
> news:f091a46.-1@WebX.maYIadrTaRb...
> > I am new at this, can somebody please help.
> > here is my lisp routine:
> > (defun drawPline()
> > (setq p (getpoint "\nPlease Select Starting Point: "))
> > (command "pline" P)
> > the result i got is this:
> > Command: (drawPline)
> > Please Select Starting Point: pline
> > Specify start point:
> > Current line-width is 0.0000
> > Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: nil
> > is there a way to make it so that i would get only this:
> > Since the first point was already asked, I do not want to see it again
in
> the command-prompt. Also I do not understand why 'nil' is on the first
> 'Specify next point' line.
> > Any help is appreciated.
