I have some drawing that contains PHANTOM2 linetype.
I can't delete this linetype from my drawings!
does anybody has any idea?
Please see the attached drawing.
Abbas
Solved by Lee_Mac. Go to Solution.
it's not part of imported DGN drawing.
Becuse I used "DGNPURGE" command and the result was:
Purged 0 unreferenced complex linetype records (of 0). Purged 0 unreferenced strokes (of 0).
if you are intersetd to test, please download attached hotfix for having "DGNPURGE" command.
Abbas
I tried WBLOCK (Entire drawing) too, It does not purge the linetype:
(defun C:ReWriteDWG ( / f) (setq f (strcat (getvar 'dwgprefix) (vl-filename-base(getvar 'dwgname)) "_wblock.dwg")) (if (findfile f) (command "-wblock" f "Y" "*") (command "-wblock" f "*")) )
Abbas
I deleted all entities and purge one of my drawing and then uploaded here to show you! It's suprising, It's blank and empty drawing but if you uses STATUS command you will see:
There are 140 objects in the PHANTOM2.dwg!! (system variables,....)
Abbas
@Abbas
and
@mid-awe
I'm using AC2014, and I don't have in this pc AC2013, but attached is a dxf, open it with the notepad and you can see that there is no reference to PHANTON2 ltype...
Henrique
Henrique,
you can see our dxf too.
AcDbLinetypeTableRecord 2 PHANTOM2 70 0 3 Phantom (.5x) ___ _ _ ___ _ _ ___ _ _ ___ _ _
Abbas
Abbas,
the first thing I did was to create a dxf from the first dwg you posted, and open it with notepad and I have seen the PHANTOM2 linetype...
Henrique
Abbas, You should look into any application that you have loading automatically. I opened the dxf file that Henrique provided and there is no reference to Phantom2 in the file. Also, once opened in AutoCAD 2013, I do not find the reference either.
* I saved the dwg for you. I did attach it below.
Abbas,
when you create the block did you select the Entire drawing option?
this is the option I use, when I want to "clean" the dwg...
Henrique
YES, there is no PHANTOM2 linetype in your attached dwg file.
but my problem stills!
I cant delete it!
There is no auto load program for my AutoCAD.
this is your file:
Abbas
