Visual LISP, AutoLISP and General Customization
How to change layer name
17 REPLIES 17
Message 1 of 18
BeKirra
866 Views, 17 Replies
How to change a layer name? for example, change an existing layer's name from "Text" to "Message".
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
17 REPLIES 17
Message 2 of 18
3wood
in reply to: BeKirra
Use command RENAME
Message 3 of 18
BeKirra
in reply to: 3wood
Sorry, I meaned that using DXF method. for example, it allows users to modify the linetype, color while changing the layer name.
Thanks.
X² + Y² = C²
Message 4 of 18
_Tharwat
Try this .
(if (and (setq e (entget (tblobjname "LAYER" "Text")))
         (not (tblsearch "LAYER" "Message"))
  (entmod (subst '(2 . "Message") (assoc 2 e) e))
Message 5 of 18
BeKirra
in reply to: _Tharwat
Thanks a lot. It works.
What is the best way to change a layer name, for example from "TEXT" to "Text"?
X² + Y² = C²
Message 6 of 18
_Tharwat
The same but you need to remove the table search function because it is not case-sensitive in this case .
eg.
(if (setq e (entget (tblobjname "LAYER" "TEXT")))
  (entmod (subst '(2 . "Text") (assoc 2 e) e))
Message 7 of 18
BeKirra
Thanks for your help again.
Is it possible to make the table search function case-sensitive so if no layer name found as "TEXT" the routine will do nothing?
X² + Y² = C²
Message 8 of 18
_Tharwat
You can do that without the use of the tblsearch function via collecting all layer names and check each name separately if it is matchs any name you would like .
Message 9 of 18
BeKirra
 Thanks. How to make it works by "collecting all layer names".
X² + Y² = C²
Message 10 of 18
_Tharwat
Try .
(defun _table:layers (/ l nm lst)
  (while (setq l (tblnext "LAYER" (not l)))
    (if (not (wcmatch (setq nm (cdr (assoc 2 l))) "*|*"))
      (setq lst (cons nm lst))
  (reverse lst)
Message 11 of 18
BeKirra
  (reverse lst)
Thanks again. From your code it returns a list of layer names.
How do I get the layer name (e.g. "Text") from the list?
Sorry I do not know much about list and dxf functions.
X² + Y² = C²
Message 12 of 18
_Tharwat
One way.
(member "Text" (_table:layers))
Another .
(vl-some '(lambda (x) (eq "Text" x)) (_table:layers))
Message 13 of 18
BeKirra
 Thanks. Now I noticed that both of 2 codes above are case sensitive.
Here is another question. Based on your posts earlier, I am going to modify my another code. I want to change a layer name but it does not work. Here is my code:
(if (setq GetLayerName (cdr (assoc 2 (entget (tblobjname "LAYER" "Existing Machine")))))
	(progn (setq ChangeLayerName (strcat "\"" "Removed Machine" "\""))
		   (entmod (subst '(2 . ChangeLayerName) (assoc 2 GetLayerName) GetLayerName))
What is wrong?
X² + Y² = C²
Message 14 of 18
_Tharwat
First the variable GetLayerName represent layer name and not the dxf list .
Second the layer name must not have any kind of symbols , so it would fail .
Message 15 of 18
BeKirra
What I'm now trying to achieve is the following:
1) manually enter a new layer name (e.g. Removed Machine), perheps use "getstring".
2) then replace the an existing layer name. e.g. "Existing Machine".
How to make it to work? Thanks.
X² + Y² = C²
Message 16 of 18
_Tharwat
If you are trying to change the same layer name but with Capital or Small letters , this should NOT work but only with COMPLETELY new VALID layer name.
(defun c:test (/ old-layer-name new-layer-name elist)
  ;;	Tharwat 18.09.2014	;;
  (if (and (/= (setq old-layer-name (getstring t "\n Specify existed layer name :")) "")
           (if (not (tblsearch "LAYER" old-layer-name))
             (progn (alert (strcat "Layer Name : < " old-layer-name " > is not found !!")) nil)
             t
           (/= (setq new-layer-name (getstring t "\n Specify New layer name :")) "")
           (if (or (tblsearch "LAYER" new-layer-name) (not (snvalid new-layer-name)))
             (progn (alert (strcat "Layer Name : < " new-layer-name " > is already existed or not valid new name !!"))
                    nil
             t
    (entmod (subst (cons 2 new-layer-name)
                   (assoc 2 (setq elist (entget (tblobjname "LAYER" old-layer-name))))
                   elist
  (princ)
Message 17 of 18
BeKirra
 You give me no hope... Smiley Sad
But thanks so much for your time and helps anyway. Cheers.
X² + Y² = C²
Message 18 of 18
pbejse
Is that all you are wanting to do? or if theres an existing layer name you wanted it to look as you typed on getstring prompt?
”Boost
