Hi all,
the following message is returned:
"Command: ; error: Unknown exception occurred
; warning: unwind skipped on unknown exception"
this occur because of following situation:
- in the file "A", is running a AutoLISP code that create a new file "B";
- in the file "B", a reactor, call other code that create details of a 3d, and return for the file "A",
- this all is run perfect; however if user close the file "A" before display manualy, of file "B" (ctrl + tab) the exception is returned in file "B"
Is possible prevent this exception?
Thanks!
Marcelo Silva - Brazil
This is not an AutoLISP error message, but seems to be something emanating from the native AutoCAD code, therefore I don't think you can "intercept" it (except maybe if it is a custom ARX or something and you have the source code), buit rather make sure to do the things the right way.
