how to access to nested ojects with ssget function?
3 REPLIES 3
ahmet471985
616 Views, 3 Replies
how can i access to nested objects with ssget?
3 REPLIES 3
Kent1Cooper
in reply to: ahmet471985
I don't think you can -- I believe (ssget) "sees" only top-level objects.  Look into (nentsel) and/or (nentselp).  Both require individual selection of each nested object, so they won't find multiples the way (ssget) can find multiple top-level objects at the same time, but depending on your application, they may work for you.
Kent Cooper, AIA
ahmet471985
in reply to: Kent1Cooper
How to use :N mode in ssget?
paullimapa
You can read up more on what the :N option does on Lee Mac's site: http://www.lee-mac.com/ssget.html#format
But I would not use the :N option in ssget as Lee Mac states that the results are erratic so therefore you cannot depend on it.
You can however use the standard ssget function and then use ssname to grab the ententity and then drill down to the nested entity you're looking for.
Paul Li
IT Specialist
@The Office
”Boost
