I am try to search for atoi in help but it returns nothing. I using autocad map 2012. How do get just autolisp and visual lisp help?
I know the new help version in 2012 sucks big time but what are you going to do. Press the F1 key and go to Developer Documentation, then AutoLISP Reference Guide and then AutoLISP Functions.
Then I don't know what to tell you. Did you do a full install? See attached, for atoi data.
i did find htm file outside of Autocad help and here is location
C:\Program Files\Autodesk\AutoCAD Map 3D 2012\Help\filesALR\WSfacf1429558a55de1a7524c1004e616f8b-5913.htm
