Visual LISP, AutoLISP and General Customization
How get lisp variable (point) in vb.net ?
2 REPLIES 2
ButterFlyShame
1023 Views, 2 Replies
Hello there. I found below lisp in internet. What is does is , It will find the bounding box of selected object and it put those data in minpoint and maxpoint variable and show them in command prompt.
with this format ( x1 y1 z1 , x2  y2 z2)
I believe , right term is " Buffer ".
Now my question is , how can I can read  X,Y
coordinates of those point in  vb net.
Or at least write them in a file.
I nice example would be helpful because I am not a pro.
Thanks for all help.
(defun C:minmax()
(setq BarEname (cdr (car (entget (car (entsel "\nselect your object "))))))
(ucs-bbox BarEname)
;; can be used with vla-transformby to
;; transform objects from the UCS to the WCS
(defun UCS2WCSMatrix ()
(vlax-tmatrix
  (append
    (mapcar '(lambda (vector origin) (append (trans vector 1 0 t) (list origin)) )
              (list '(1 0 0) '(0 1 0) '(0 0 1))
              (trans '(0 0 0) 0 1) )
    (list '(0 0 0 1))
;; transform objects from the WCS to the UCS
(defun WCS2UCSMatrix ()
  (vlax-tmatrix
    (append
      (mapcar '(lambda (vector origin)(append (trans vector 0 1 t) (list origin)))
               (trans '(0 0 0) 1 0)
      (list '(0 0 0 1))
;; Returns the UCS coordinates of the object bounding box about UCS
;; Argument
;;   obj : a graphical object (ename or vla-object)
;; Return
;;   a list of left lower point and right upper point UCS coordinates
(defun ucs-bbox (obj / minpoint maxpoint)
  (vl-load-com)
  (and (= (type obj) 'ENAME)
       (setq obj (vlax-ename->vla-object obj))
  (vla-TransformBy obj (UCS2WCSMatrix))
  (vla-getboundingbox obj 'minpoint 'maxpoint)
  (vla-TransformBy obj (WCS2UCSMatrix))
  (list (vlax-safearray->list minpoint)
        (vlax-safearray->list maxpoint)
2 REPLIES 2
JustoAg
in reply to: ButterFlyShame
You may try this approach:
(defun C:minmax ()
   (setq pointList (ucs-bbox BarEname))
   (setq f (open "AFile.tmp" "w"))
   (print pointList f)
   (close f)
  (princ)
Now, parse and read this file from vb.net. Deleted it when finished.
Hope this helps.
Justo Aguiar
ButterFlyShame
in reply to: JustoAg
Hello JustoAg,
Your Code worked Perfect. Thanks,
Thanks again. I am so happy with this site and proffesional people who signed in.
”Boost
