Visual LISP, AutoLISP and General Customization
How do I select points by point group
2 REPLIES 2
jamesbarnett
704 Views, 2 Replies
I wanto to have a point group created and be able to use it to select my points. If that is possible can it be prompted to select the points or use the point group?
(prompt "\nSelect points to report: ")
   (setq pts (ssget)
 len (sslength pts)
 ctr 0)
AutoCAD Civil 3D 2022
2 REPLIES 2
Jonathan3891
in reply to: jamesbarnett
Did a quick google search and found this:
http://forums.autodesk.com/t5/autocad-land-desktop/selecting-point-groups-for-autocad-commands/td-p/...
Hope it helps
Jonathan Norton
Blog | Linkedin
doni49
in reply to: Jonathan3891
LDD is different from C3D.  Although that would be worth trying, I wouldn't be surprised if that doesn't work.
If you find that it in fact doesn't, I think you'd be better served asking this question over on the Civil 3D Customization board.
http://forums.autodesk.com/t5/autocad-civil-3d-customization/bd-p/190
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
”Boost
