I wanto to have a point group created and be able to use it to select my points. If that is possible can it be prompted to select the points or use the point group?
(prompt "\nSelect points to report: ")
(setq pts (ssget)
len (sslength pts)
ctr 0)
Did a quick google search and found this:
Hope it helps
LDD is different from C3D. Although that would be worth trying, I wouldn't be surprised if that doesn't work.
If you find that it in fact doesn't, I think you'd be better served asking this question over on the Civil 3D Customization board.
http://forums.autodesk.com/t5/autocad-civil-3d-customization/bd-p/190
Don Ireland
Engineering Design Technician
