I have a lisp that will place a point by entering DMS or DD coordinats. But it only works in UTM zone 13.
How do I make it work for any UTM zone?
(defun c:PDMS (/ *error* which coord) (vl-load-com) (defun *error* (msg) (if (member msg '("console break" "Function cancelled" "quit / exit abort") ) (setq *error* outtahere) ) ) (initget 1 "DMS DD") ; choose dms or dd (setq which (strcase (getkword "Dms or Decimal degrees: (DMS or DD) ")) ) (if (= which "DMS") (setq lat (angtof (getstring "Latitude: ") 1) ; if dms long (angtof (getstring "Longitude: ") 1) ) (setq lat (angtof (getstring "Latitude: ") 0) ; if dd long (angtof (getstring "Longitude: ") 0) ) ) (geo2utm lat long) ; convert this lat/long to utm (setq coord (list east north)) ; this is the start point (setvar "pdmode" 34) (command "point" coord) ; place point (while (/= coord "") ; repeat (if (= which "DMS") (setq lat (angtof (getstring "Latitude: ") 1) long (angtof (getstring "Longitude: ") 1) ) (setq lat (angtof (getstring "Latitude: ") 0) long (angtof (getstring "Longitude: ") 0) ) ) (if (or (= long nil) (= lat nil)) (progn ; if lat or long nil (setq *error* outtahere) ; reset *error* (setq coord "") ; end the pline command ) (progn ; if not nil (geo2utm lat long) ; calculate next utm coord (setq coord (list east north)) ; put as a list ) ) (command coord) ; enter next point or end ) ; end while (princ) ) ; end defun ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;Converts from geographic to utm. Works for utm NAD 27 or 83 only. ;;;Takes two arguments, first the lat and then the long as reals in ;;;radians. Note that west longitude is entered as positive. (defun geo2utm (lat long / a c1 c2 c3 c4 c5 c6 c7 ce1 ce2 ce3 ce4 ce5 ce6 cm cp den emult es1 es2 fan fe Flattening ma MajorAxis MinorAxis nad r sfac smerid sp sp2 t2 t4 TP v vr w W1 W2 W3 W4 W5 X z0 z1 z2 z3 z4 z5 z6 zn zone ) (setq nad (ade_projgetwscode)) (setq temperr *error*) (if (= nad "") (setq *error* trapnocrdsys) ) (setq a (+ (vl-string-search "-" nad) 1)) (if (not (or (= (substr nad 1 (1- a)) "UTM27") (= (substr nad 1 (1- a)) "UTM83") ) ) (progn (setq *error* trapnot27or83) (setq a nil) ) ) (if (= (substr nad (strlen nad)) "F") (progn (setq *error* trapnotM) (setq a nil) ) ) (setq zone (atoi (substr nad (+ 1 a)))) (if (/= zone 13) (progn (setq *error* not13) (setq a nil) ) ) ;;;;;;;;;;;;;;;;;;;;;;;; define the ellipse (if (= (substr nad 1 (1- a)) "UTM27") (setq MajorAxis 6378206.4 ; NAD27 Flattening 294.9786982 ) (setq MajorAxis 6378137.0 ; NAD83 Flattening 298.257223563 ) ) (setq MinorAxis (* MajorAxis (/ (- Flattening 1.0) Flattening)) es1 (- 1.0 (* (/ MinorAxis MajorAxis) (/ MinorAxis MajorAxis))) es2 (/ es1 (- 1.0 es1)) sfac 0.99960000000 fe 500000.00000000 fan 0.0 cm (/ (* (- (* 6.0 zone) 183.0) pi) 180.0) ma (* MajorAxis (- 1.0 es1)) ce1 (+ 43659.0 (* 693693.0 (/ es1 16.0))) ce2 (+ 11025.0 (* (/ es1 4.0) ce1)) ce3 (+ 175.0 (* (/ es1 64.0) ce2)) ce4 (+ 45.0 (* (/ es1 4.0) ce3)) ce5 (+ 3.0 (* (/ es1 16.0) ce4)) ce6 (+ 1.0 (* (/ es1 4.0) ce5)) c1 ce6 c2 (- c1 1.0) c3 (* es1 (/ es1 32.0) (+ 15.0 (* es1 (+ (/ 175.0 12.0) (* es1 (+ (/ 3675.0 256.0) (* es1 (+ (/ 14553.0 1024.0) (/ (* es1 231231.0) 16384.0)) ) ) ) ) ) ) ) c4 (* es1 es1 es1 (+ (/ 35.0 96.0) (* es1 (+ (/ 735.0 2048.0) (* es1 (+ (/ 14553.0 40960.0) (/ (* es1 232231.0) 655360.0)) ) ) ) ) ) c5 (* es1 es1 es1 es1 (+ (/ 315.0 1024.0) (* es1 (+ (/ 6237.0 20480.0) (/ (* es1 99099.0) 327680.0))) ) ) c6 (* es1 es1 es1 es1 es1 (+ (/ 693.0 2560.0) (/ (* es1 11011.0) 40960.0)) ) c7 (/ (* es1 es1 es1 es1 es1 es1 1001.0) 4096.0) w (- (* -1.0 long) cm) ) (if (>= long pi) (setq w (- (* 2.0 pi) w)) ) (setq emult -1.0) (if (<= w 0.0) (setq emult 1.0) ) (setq w (abs w) sp (sin lat) sp2 (* sp sp) cp (cos lat) tp (/ (sin lat) (cos lat)) t2 (* tp tp) t4 (* t2 t2) den (- 1.0 (* es1 sp2)) v (/ majoraxis (sqrt den)) r (/ (* v (- 1 es1)) den) vr (/ v r) x (* w w cp cp) zn (+ c5 (* sp2 (+ c6 (* sp2 c7)))) smerid (* ma (- (* c1 lat) (* sp cp (+ c2 (* sp2 (+ c3 (* sp2 (+ c4 (* sp2 zn)))))) ) ) ) z0 (/ (* x v tp) 2.0) z1 (- 1385.0 (* t2 (- 3111.0 (* t2 (- 543.0 t2))))) z2 (- (* vr (+ 1.0 (* vr 4.0))) t2) z3 (- 1.0 (* t2 32.0)) z4 (- 28.0 (* 168.0 t2)) z5 (- 88.0 (* 192.0 t2)) z6 (- z3 (* vr (- z4 (* vr z5)))) ) ;;; Calculate northing (setq north (+ smerid (* z0 (+ 1.0 (* (/ x 12.0) (+ z2 (* (/ x 30.0) (- t4 (+ (* vr (- (* 2.0 t2) (* vr z6))) (* (/ x 56.0) z1) ) ) ) ) ) ) ) ) ) (setq north (- (* north sfac) fan)) (if (< north 0.0) (setq north (* -1.0 (+ north 10000000.0)) ) ) ;;; Calculate easting (setq w1 (+ 61.0 (* 479.0 t2 -1.0) (* 179.0 t4) (* t4 t2 -1.0)) w2 (- 4.0 (* 24.0 t2)) w3 (+ 1.0 (* t2 8.0)) w4 (+ w3 (* vr w2)) w5 (* w v cp) east (* w5 (+ 1.0 (* (/ x 6.0) (+ (- vr t2) (* (/ x 20.0) (+ (- t4 (* vr (- (* 2.0 t2) (* vr w4)))) (* (/ x 42.0) w1) ) ) ) ) ) ) ) (setq east (+ (* -1.0 east emult sfac) fe)) ) ;end defun (defun trapnocrdsys (errmsg /) (setq *error* temperr) (alert "The coordinate system has not been set correctly.") (princ) ) (defun trapnot27or83 (errmsg /) (setq *error* temperr) (alert "The routine only works for NAD27 or 83.") (princ) ) (defun trapnotM (errmsg /) (setq *error* temperr) (alert "The coordinate system is not set to meters.") (princ) ) (defun not13 (errmsg /) (setq *error* temperr) (alert "The drawing isn't zone 13!.") (princ) ) (defun outtahere (errmsg /) (setq *error* temperr) (princ) )
