Visual LISP, AutoLISP and General Customization
*Expert Elite*
Kent1Cooper
Message 11 of 16 (574 Views)
Re: How convert a Spline to a curved leader
06-13-2012 12:09 PM in reply to: HS20EXR
HS20EXR wrote:
.... I avoid using leaders because they prompt for adding text at the end of the command and it's "difficult" to exit the command without adding text. ....
That's not what's difficult, in my opinion.  This will do that part quite handily:
(defun C:test (/ pt)
  (command "_.leader" pause pause "_format" "_spline")
  (while (setq pt (getpoint (getvar 'lastpoint) "\nSpecify next point: "))
    (command pt); feed out to Leader command
  ); end while [loop ended by Enter/space instead of picking point]
  (command "" "" "_none")
The difficult [maybe impossible?] part, in my trials, is to get it to show you the Leader under construction along the way.  The above collects points, and afterwards builds a spline-format Leader, with no text, based on them.  I tried various things in an attempt to see it in progress, but so far without success.
Kent Cooper
HS20EXR
Message 12 of 16 (568 Views)
06-13-2012 01:22 PM in reply to: Kent1Cooper
It works fine, you made it look easy. It's an ingenious solution. This comes very close to what I am looking for. Of course, in theory it would be better to see the leader under construction along the way but that's not really an issue. Practically, it works fine, it's easy to predict what it would look like, it's usually made of 3-4 points. I'll start using it today.
I appreciate it, thank you Master Cooper.
*Expert Elite*
Kent1Cooper
Message 13 of 16 (557 Views)
06-13-2012 02:41 PM in reply to: HS20EXR
You're welcome.  If, like me, you draw with Blipmode on, you can at least see the points you've picked, and get a pretty good feel for what the Leader is going to look like, as you go.
Kent Cooper
HS20EXR
Message 14 of 16 (550 Views)
06-13-2012 04:24 PM in reply to: Kent1Cooper
I don't draw with BLIPMODE on, but you gave me the idea to turn it on for this program only and then go back to BLIPMODE off.
(defun C:Test (/ pt)
(setq blipmode (getVAR "BLIPMODE"));; this is 0 usually
(defun *error* (msg)
(princ msg)
(setvar "BLIPMODE" blipmode)
;(setvar "BLIPMODE" 0)
(princ))
(setvar "BLIPMODE" 1)
;; (setvar "BLIPMODE" 0) ;reset BLIPMODE
(setvar "BLIPMODE" blipmode) ;reset BLIPMODE- this should be 0
The thing is if I hit ESC repetitively after I pick a few points BLIPMODE doesn't reset to 0 (which I expect) but stays on. I guess it's not an error so the error code doesn't run and the last line of code that resets the BLIPMODE to initail value (which is 0) doesn't run either. Would you know how to fix that?
Valued Mentor
Ian_Bryant
Message 15 of 16 (539 Views)
06-13-2012 08:25 PM in reply to: HS20EXR
you could try something like:
(defun c:test ()
(setvar "cmdecho" 1) (setvar "nomutt" 0)
(command "_.leader" pause pause "_format" "_spline" pause)  (terpri)
(while
   (and
     (/= (getvar "cmdactive") 0)
     (/= (getvar "LASTPROMPT") "Enter first line of annotation text or <options>:")
   (command pause) (terpri)
(command  "" "_none")
(princ)
Ian
HS20EXR
Message 16 of 16 (516 Views)
06-14-2012 09:06 AM in reply to: Ian_Bryant
This works perfectly. Many thanks!
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
