Visual LISP, AutoLISP and General Customization
How can I automatically issue a 'Resume' command if the script fails?
3 REPLIES 3
mdhutchinson
623 Views, 3 Replies
How might I automate issuing 'RESUME' in a script if the script fails?
3 REPLIES 3
BlackBox_
in reply to: mdhutchinson
There's obviously a reason why the Script failed, so to programmatically 'resume' could put you in an endless loop.
"How we think determines what we do, and what we do determines what we get."
mdhutchinson
in reply to: BlackBox_
If the script has failed... then RESUME command would continue with the next line - INDEED... the next line after the line which failed. The whole point in scripts is so you can let it run - uninteripted - as well as not baby sat. This is a great place to use FileLogOn at the start of a script... so you can investigate the point of the failure.
capeesh?
dgorsman
Scripts have no user input or error handling, so if something fails bad things can happen.  The script could be continuing forward from a state where you expect it to work, but instead its issuing E;ALL;SAVE;CLOSE or simply firing off unknown options to one of the looping commands.
If you want more complex handling of error conditions, you will need to switch to something other than scripting.
”Boost
